| Question about Victoria http://forum.hddguru.com/viewtopic.php?f=7&t=35450 |
Page 1 of 1 |
| Author: | prasadsv [ June 9th, 2017, 6:34 ] |
| Post subject: | Question about Victoria |
I have one hard disk having 12gb bad sectors in beginning scanned with Victoria . If I erased the drive up to bad sectors with Victoria the remaining data is safe? HDD 160gb |
| Author: | Amarbir[CDR-Labs] [ June 9th, 2017, 13:44 ] |
| Post subject: | Re: Question about Victoria |
prasadsv wrote: I have one hard disk having 12gb bad sectors in beginning scanned with Victoria . If I erased the drive up to bad sectors with Victoria the remaining data is safe? HDD 160gb Well, Of course that is if you define a range and the process stops there ,But if there is any change in G and P list the translator shifts can occur |
| Author: | BGman [ June 10th, 2017, 17:17 ] |
Or you can use WDMarvel to cut the bad zone and to become a proud owener of a perfect hard drive with size of about 140GB. |
| Author: | Amarbir[CDR-Labs] [ June 11th, 2017, 1:29 ] |
prasadsv wrote: I have one hard disk having 12gb bad sectors in beginning scanned with Victoria . If I erased the drive up to bad sectors with Victoria the remaining data is safe? HDD 160gb Hello , Why Are You Wasting Forum Space ,This Was Already At -> viewtopic.php?f=1&t=35453 |
