 Post subject: HDDRawCopy1.10Portable contains Trojan?
PostPosted: September 1st, 2017, 18:34
Hello all,
I uploaded HDDRawCopy1.10Portable to virustotal and it says it contains a known ransomware Trojan.
Anyone test any of the other executables found on this site?
-Joe
 Post subject: Re: HDDRawCopy1.10Portable contains Trojan?
PostPosted: September 1st, 2017, 18:38
I think it's just a false positive. Probably something in how it's coded that makes it appear "virusy".
PostPosted: September 1st, 2017, 19:03
Upload the EXE to https://www.virustotal.com/
PostPosted: September 1st, 2017, 19:25
Sorry, I see you have already done that.
PostPosted: September 11th, 2017, 1:04
Its a false positive.
PostPosted: September 11th, 2017, 2:40
unusual though to specify Ransomware. usually these sorts of applications that get deep into the system will either flag on the protector/packer the author uses on the .exe, or will pop because of the low level access.
Possible that another Ransomware uses the same "something" as the tool, might be a good idea to check in depth before whitelisting.
