My Cloud Mirror 16 Tb ext reading problem
Posted: October 9th, 2017, 11:50
Hi all,
I recently receive a My Cloud Mirror 16 Tb (RAID-1 with 2 8Tb disks). Disk 1 with bad sectors, the client formatted this one and now he don“t have access to data.
I check disk 2 with UFS and others and I can see 3 ext partitions. None of them contains file structure. The partition is not encrypted (I see many valid text strings in Winhex, and I can recover a lot of data doing a raw recovery), but in this case, it is needed to obtain the original structure (names and dates).
I already check in WD forums but I only get one clue: Someone say The My Cloud does not use a standard Linux build. It was built with 64k page size rather than the normal 4k.
So please... How can I change the page size with Winhex, UFS or PC3k to see if this is the problem? Anyone can point me in the right direction?
Thank you very much in advance...
