Hi guys.. Need help with my WD. Making clicking noise
Posted: October 28th, 2017, 2:52
by s0p3r
I found out this forum a bit late..
I made big mistakes :cry:
Hope the data still can be recoverd.
I opened the drive and twisted a bit the top head and plugged the usb and powered it.
I also dropped a screw driver but no marks left, i know its still realy bad.
I didn't knew what is the problem but after seeing a few videos i noticed that all the heads should move when it powered on.
And only the top head moved.
I wanted to buy and replace the heads my self but i probably need to buy the right tools from HDDsurgery right? And the price is high so its better to send it to the lab.
But after doing the stupid things i've done is there a chance they will be able to recover the data?
And another last ques..
I couldn't find a hard drive with the same DCM. Is that important to have also the right DCM?
Re: Hi guys.. Need help with my WD. Making clicking noise
Posted: October 28th, 2017, 7:17
by mr_spokk
In this state it will not be at the lower price tag, where in the states are you located?
Posted: October 29th, 2017, 15:49
by s0p3r
Thank you
I'm currently in Israel. Prices are high here as well but lower i believe then Sweden Or the US.
What i did so far is to use EaseUS to recover images i had in the past on my working HD's. Laptop and Another external HD. Didn't recover all of them.
Posted: October 29th, 2017, 18:30
by HaQue
I don't do internal work, but I didn't know heads could move separately, some have headstacks where heads move across platter at different times?
The other things in the OP first message don't sound good, but ignoring that for a moment..
Posted: October 29th, 2017, 19:40
by craig6928
what would help the forum out is first knowing the model of the western digital you have.
1tb or 2tb or more or less
as there be a lot of heads on bigger drives and more problems to over come.
also all head-stacks move together and not one at a time
replacing the old head-stack with a new one your going to need a head-stack tool.
which is going to cost you money.
and finding the correct head-stack for that model of drive.
this will be a expensive hobby your have and possible lose money
in the process.
if the data is important sent it to a pro and dont try DIY
