HDD GURU FORUMS
http://forum.hddguru.com/
MHDD can't get it to run
http://forum.hddguru.com/viewtopic.php?f=7&t=36033
Page 1 of 1
Author:  n8lbv [ November 4th, 2017, 15:21 ]
Post subject:  MHDD can't get it to run
I've tried 3 different MHDD boot CDs including most recent.
All I get is a win98 boot disk telling me HMA is not available then COMMAND NOT FOUND
Then General Failure WRITING DRIVE A
What am I doing wrong?
It's a newer Lenovo Skylake based workstation with 8GM of RAM.
Intel built in graphics (maybe that is messing with HMA?)
Anyhow I am trying to fix a messed up SSD and MHDD will not even run on this.
I am trying to follow these instructions:
However I'm stuck at mhdd not running at all.
And apparently because HMA is not available to it.
http://www.tested.com/forums/pc-and-mac ... tion-here/
Author:  BGman [ November 5th, 2017, 10:34 ]
Post subject:  Re: MHDD can't get it to run
MHDD knows nothing about the chipset of your laptop.
MHDD knows nothing about SSD either... :shock:
Author:  fzabkar [ November 5th, 2017, 12:29 ]
What? :shock:
Did you read the OP's link before commenting? Apparently not.
To the OP, try this instead:
https://askubuntu.com/questions/409684/image-or-reset-broken-ssd
Author:  labtech [ November 5th, 2017, 18:55 ]
Is the BIOS set up for legacy mode?
http://www.phpbb.com/
