DDI v3 won't read/identify source drives (Probably dumb q.)
Posted: May 12th, 2018, 18:26
I know this shows just how ignorant I am - but for some reason I'm unable to ever get my DDI v3 to ever acknowledge a source drive.
- Tried the original (old old) DDI v.3 version, then upgraded it to the newest release
- Both versions appear to have the same problem.
- I've confirmed it's getting correct voltage.
- Green light is flashing on the DDI
- Destination drive connected to DDI is visible.
- F11 powers the source - but it still won't recognize it.
I've ordered a replacement PCI card...
I've tried two different brand new PATA to SATA adapters...
Computer boots, will run any OS I'd like; FreeDOS, DeepSpar's DOS, Windows.
Though I've ordered a duplicate replacement PCI PATA/SATA card, I'm skeptical it'd resolve anything. If the PATA cable or card weren't working, then the DeepSpar device shouldn't be able to load it's recovery environment.
As I've never set this unit up before (previously it was used by my cohorts) I believe it works. That said, I also bet I'm overlooking something stupid. Any help would be appreciated.
(Yes, I have a DDI 4, but I'd like to see what use this device has before I consider selling it.
Thank you,
Truman
Thank you,
Truman
