 Post subject: Eprom
PostPosted: June 22nd, 2018, 16:39
I have a Color Computer 2 and I want to put more then 1 program on a rom pak so that why I want to do this. That I can use jumper to change to which block I need.
Is there away 2 8k blocks or lower and high with a 2716. Which pins will do it?
Is there away 4 8k blocks or lower and high with a 2732. Which pins will do it? If not then 2 16 blocks or lower and high with a 2732. Which pins will do it?
 Post subject: Re: Eprom
PostPosted: June 22nd, 2018, 16:59
Just delete this thread I got help before and I thought I might help again SORRY.
Have a good day.
PostPosted: June 22nd, 2018, 19:12
For that kind of thing, you will get better results / help in a forum dedicated for old computers and videogames.
There may be a description of the modifications necessary for what you want to do in one of those. Anyway it is a kind of thing that can be better assisted by people with one of these machines to look and compare.
