Newbie questions regarding HDD Raw Copy Tool
Posted: December 4th, 2018, 18:23
I've got an SDcard which I had previously used as combined storage in my Android phone. Recently I needed to copy some files from my phone to my PC via USB. At some point during copying the SDcard became corrupt, as under system settings the system said so. Though only logically corrupted, as I could still physically read the card when connecting to my PC, just with barely any data on it. Fortunately I successfully copied my phone's entire DCIM folder along with some other stuff, so all my really important stuff has been secured (I really jumped the gun on that one). I knew that I should've rooted my phone, so I could've made a full image backup of my phone in case anything like this would happen. Then again, I didn't know that combining external SD and internal storage into one pool can be unstable on Android. It's only afterwards that I learned that it can indeed happen for the SDcard to become corrupt at some point, requiring you to reformat and re-add it to the system.
I want to reformat the SDcard, but before I do so, I want to make a 1:1 raw copy of the state of the bits on the SDcard, so that I can try and attempt to recover data from it at a later point. I found HDD Raw Copy Tool through Google, and I hope that it can get the job done. But I've got a few questions below that I need answered before I can try anything with some degree of confidence.
- Will HDD Raw Copy Tool not alter any bits on the card when a raw copy is being made?
- If I set my C: drive as my target drive, will HDD Raw Copy Tool overwrite any data on C: (even if there's sufficient free space for the raw copy)? Or will it just create an image of the source drive and place the file somewhere on C: (no file location is being asked when doing so)?
- Which file format will HDD Raw Copy Tool use to copy a drive? And will that file format be compatible with third party recovery software?
- Is it perfectly fine to use HDD Raw Copy Tool over USB? It concerns an SD card, so it's not like I've got much choice, but still asking to get a better understanding of HDD Raw Copy Tool.
- Would you recommend a tool that you find better than HDD Raw Copy Tool?
