| Corrupted File http://forum.hddguru.com/viewtopic.php?f=7&t=38036 |
Page 1 of 1 |
| Author: | Herbert_Taylor [ February 7th, 2019, 5:18 ] |
| Post subject: | Corrupted File |
Can I repair a corrupted. MP4 video file? |
| Author: | MindMergepk [ February 7th, 2019, 6:30 ] |
| Post subject: | Re: Corrupted File |
yes, depends on the extent of the problem. was this file carve by a data recovery software ? what is the camera model ? |
| Author: | Dananjaya [ February 19th, 2019, 4:49 ] |
still you need this ? if yes, then pls. explian whole problem. is this formatted recovered chip? i think normally you mean canon 80d, 5d mark iv(there are two types 5d mk4) sony pxw series and gopro or drone. this all models can be recovered 90% - 100% |
| Author: | HaQue [ February 19th, 2019, 7:16 ] |
you really think this is a real post? vague question with 0 information that could help. suspect spammer |
| Author: | Dananjaya [ February 19th, 2019, 9:38 ] |
friend HaQue. i think maybe. |
| Author: | Iurii [ February 20th, 2019, 2:34 ] |
If you need to repair video file you need some specific software. For example some video editor software that may parse video frames and generate new file that will include found data. This approach may works if you have software and not so much files. But much better to look on source(device) of this file. Does it really corrupted or you just used wrong data extraction tool? |
| Author: | Dananjaya [ February 22nd, 2019, 13:42 ] |
normally canon 80d,panasonic gh4-5, sony ex3,sony fs5, sony pxw200,red camera files and more sony files can't be repaired or recovered by software.somehow if you have repaired files sometimes it won't play properly and cant transfer to editing softwaretime line. manual recovery method only. |
| Author: | rlsturk [ May 12th, 2019, 14:20 ] |
Hi guys, i have a some serious issue with last some cases... any of memory card with canon, nikon or other without sony alpha series recovered video files can't play. & today i have a case recover from hard drive i got a video folder with same size backup but video files can't play still try many of softwares but can't recovered successfully try many of converters & repairing tools still no luck.. any friend help will be appreciated thank you |
