| How to Fix Bad Sectors that NOT shown by Surface test http://forum.hddguru.com/viewtopic.php?f=7&t=38118 |
Page 1 of 1 |
| Author: | kimi [ February 25th, 2019, 5:18 ] |
| Post subject: | How to Fix Bad Sectors that NOT shown by Surface test |
Hi everyone i usnig Hard Disk Sentinel 5.01 PRO that Program says that " there are 4 Bad sector in the Hard that cause reduce of the Health to 94% But in the Surface Test no Any Bad Sectors , And Attribute #5 Reallocated Sector Count 0 100 100 how to overcome this problem ? and any way to change values of SMART like offset them for example ? thanks |
| Author: | abolibibelot [ March 5th, 2019, 0:44 ] |
| Post subject: | Re: How to Fix Bad Sectors that NOT shown by Surface test |
If the data is not important, or is properly backed up, you could run a complete write scan; if those sectors have been marked as bad because of an inconsistent state (which can happen for instance when there's a power failure during a write operation), overwriting them should remove them from the “pending sectors” list – if that's indeed where they appear currently. Posting a screenshot of the “SMART” tab (not the “overview”) might help to refine the diagnosis. |
