dolphindatalab innovative ROM Chip Pin Reader
http://forum.hddguru.com/viewtopic.php?f=7&t=39283
Author:  LostDataSa [ December 23rd, 2019, 14:10 ]
Post subject:  dolphindatalab innovative ROM Chip Pin Reader
After seeing dolphindatalab post for their new "HDD ROM Chip Pin Reader Set" got shocked by the price
https://www.dolphindatalab.com/product/ ... mer-smart/
I have it for years before dolphindatalab announced it, the same exact tools for much less. which you find here:
https://www.aliexpress.com/item/3295968 ... 4c4dUtuGcw
You will need only Pin Distance 5.5mm and 6.4mm
It really helped me a lot, and saved my time soldering and desolating, and also I can use the PCB many many time without damaging it, So I decided to share this it may help you too.
Author:  LostDataSa [ December 23rd, 2019, 14:17 ]
Post subject:  Re: dolphindatalab innovative ROM Chip Pin Reader
with it, I can switch ROMs in 2 min
Author:  fzabkar [ December 23rd, 2019, 17:15 ]
ISTM that it would be safer if the probe had a feature which prevented it from slipping off the pins. Maybe a foam or rubber cube between the top of the IC and the base of the probe would stabilise the jig? I'm assuming the pins are spring loaded pogo pins.
Author:  michael chiklis [ December 23rd, 2019, 23:41 ]
https://www.amazon.com/gp/product/B013Y ... f86e8b1d7c
Author:  LostDataSa [ December 24th, 2019, 12:28 ]
it is spring-loaded, so no slipping
