EaseUS Data Recovery oddities...
Posted: January 23rd, 2020, 8:28
First post, please be gentle...
I have couple of HDDs that required wiping, prior to recycling them; the drives are external via USB port on a Windows 10 Pro, 64-bit desktop. The software for this purpose is Hardwipe, version 5.2.1 and used DOD 5220.22-M to erase the content of the drive. After the erase, the raw drives were scanned via EaseUS Data Recovery version 13 for verification purposes. That's where things got confusing...
EaseUS Data Recovery advanced scan of the raw drive found 30 files (712.23 GB) on a 120 GB drive, yes, on a 120 GB drive. All of the found files are shockwave flash files, extension SWF. Erasing the the drive again didn't help, EaseUS advanced scanning showed the same same results.
I created a simple partition for the 120 GB drive and formatted the drive with NTFS file system. After the format had completed, the drive had been encrypted with Windows 10's Bitlocker for external drive. Once the drive had been fully encrypted, the partition was deleted and re-scanned with EaseUS Data Recovery. The advance scan results were better than before, but it still found 26 files (44.68 GB) with SWF extension.
The drives probably never had that many shockwave files and the chances are, that the scan results are incorrect.
Is it "normal" for data recovery software to have that many "incorrect" files identified?
TIA...
TIA...
