| WD My Passport WD10TMVW http://forum.hddguru.com/viewtopic.php?f=7&t=39881 |
Page 1 of 1 |
| Author: | sigitharjono [ May 16th, 2020, 5:14 ] | |||
| Post subject: | Re: WD My Passport WD10TMVW | |||
I already tried change the ROM USB (in the circle) to ROM SATA, but it stil doesn't detect. What should i do?
| Author: | Tomset [ May 16th, 2020, 8:29 ] |
Not the chip was removed. Below U12 |
| Author: | sigitharjono [ May 21st, 2020, 1:01 ] |
I tried that, but it's still not working |
| Author: | jerovsek [ May 21st, 2020, 1:09 ] |
you need sata pcb 2060-771820 |
| Author: | sigitharjono [ May 22nd, 2020, 23:26 ] |
Yes, thank you. I successed open the password with WDMarvel software |
| Author: | sigitharjono [ May 27th, 2020, 5:56 ] |
Hello, I managed to image SATA HDD, but the result was bad. So, i restored hdd back to original (USB), but it locked again. How do i unlock it again? (E.g. = should i edit the ROM or something?) Thank You |
