| Compatible PCB http://forum.hddguru.com/viewtopic.php?f=7&t=40491 |
Page 1 of 1 |
| Author: | sigitharjono [ October 17th, 2020, 6:20 ] |
| Post subject: | Compatible PCB |
Hello, I have hd Seagate Laptop Thin 500GB with dead PCB. And i have donor pcb with similiar series (seagate laptop thin 500GB), but the firmware series is different. The broken hd firmware is HPM2 and the hd donor is HPM6. Could i exchange the ROM to get the data back? Is it compatible? Thank you |
| Author: | excell [ October 18th, 2020, 19:15 ] |
| Post subject: | Re: Compatible PCB |
you didnt mentioned the model of the drive. if the drive is not SED then you can do it , sure. |
| Author: | excell [ October 18th, 2020, 19:17 ] |
the firmware is on the platter , not in the rom. |
| Author: | sigitharjono [ October 19th, 2020, 3:18 ] |
Thank you for the answer The model is same ST500LM000. But the firmware series is a bit different HPM2 and HPM6. Is it compatible? |
| Author: | pclab [ October 19th, 2020, 3:29 ] |
Since you already have the board, just swap ROM and test. |
