| How to create a loop with several lines in MHDD batch file? http://forum.hddguru.com/viewtopic.php?f=7&t=41092 |
Page 1 of 1 |
| Author: | Alexander Firsov [ March 18th, 2021, 5:49 ] |
| Post subject: | How to create a loop with several lines in MHDD batch file? |
I want to make an MHDD batch script with the following 2 commands in a row to be repeated indefinitely or 100000 times, non-stop Code: RST INIT I know how to repeat a single line a certain number of times. But how to repeat more than one line in a row? Please advise a newbie |
| Author: | fzabkar [ March 18th, 2021, 17:49 ] |
| Post subject: | Re: How to create a loop with several lines in MHDD batch fi |
Here is an example that may help you: Code: ; read all HDD modules from Fujitsu MPG / MPE SA
reset waitnbsy ; enable VSCs regs = $fa $43 $42 $41 $40 $a0 $c1 ; get module %modid = 0 @loop: %modid = %modid + 1 if %modid = 256 @end waitnbsy regs = %modid $01 $00 $00 $00 $00 $c2 waitnbsy %error = iserror if %error = 1 @loop checkdrq sectorsto = fuj_mods\%modid.bin goto @loop @end: |
| Author: | Alexander Firsov [ March 19th, 2021, 4:39 ] |
Thank you Will the following batch script work in MHDD 4.5 Code: @loop:
reset %error = iserror if %error = 0 @end goto @loop @end: |
| Author: | Alexander Firsov [ March 19th, 2021, 7:49 ] |
Sorry, I forgot one line in the batch script Code: @loop:
reset init %error = iserror if %error = 0 @end goto @loop @end: |
| Author: | fzabkar [ March 19th, 2021, 9:56 ] |
Seems OK to me. |
| Author: | fzabkar [ March 19th, 2021, 15:25 ] |
You may like to try HDDSuperTool. It's a lot more versatile and fully documented. http://www.hddsuperclone.com/sitev1/hddsupertool |
| Author: | Alexander Firsov [ March 19th, 2021, 23:20 ] |
fzabkar wrote: You may like to try HDDSuperTool. It's a lot more versatile and fully documented. http://www.hddsuperclone.com/sitev1/hddsupertool Many thanks. I didn't know this software. Unfortunately my SSD disk is so sick that only DOS can detect it. I tried many Linux tools, all of them are not detecting my faulty drive. I have to work with the drive at the lowest possible level in DOS environment. |
