 Post subject: NVME USB casings not working
PostPosted: August 19th, 2021, 2:37
I have referred thread on ideal dr specific casing on hddguru forum. Based on various in puts I have ordered 3-4 casings. But none of them is working for a nvme SSD . SSD as such is not having any issues as it is detected in original laptop and even windows is getting loaded .(D drive is not accessible)
Can someone pls. suggest a latest generation of USB casing.
 Post subject: Re: NVME USB casings not working
PostPosted: August 19th, 2021, 23:19
Check which chipset is used in Nvme Adapater that is shipped with acaelab portable. developers must have done extensive R&D before choosing chipset. Someone having portable might help.
PostPosted: August 25th, 2021, 0:43
From anandtech forum --
RTL controller is using a more advanced process and will also run cooler/use less energy.
ASM2362 - Seems to run fine on an X570 MB and Intel
JMB583 based enclosures become hot and different firmwares have varied results.
You will have to buy all of them and give it a try. There is compatibility issues with SSD models and enclosures.
Users browsing this forum: benjaminnelson and 25 guests
