 Post subject: MHDD with 4TB disk
PostPosted: August 28th, 2021, 16:20
Hi.
With MHDD I am using a 4TB disk with LBA 7,814,037,168.
The problem is that when doing ERASE the final sector 3,519,069,871 appears (slightly less than half).
I have tried /DISABLEBIOS when starting MHDD, it goes into PIO mode but the final sector remains the same.
Why the limit this one?
 Post subject: Re: MHDD with 4TB disk
PostPosted: October 31st, 2021, 19:16
Have you tried this on a different motherboard with a different chipset? Could be some sort of limit on the hardware that's affecting the software.
PostPosted: October 31st, 2021, 23:34
There appears to be a 32-bit LBA limit.
    7,814,037,168 - 2^32 = 3519069872
PostPosted: October 31st, 2021, 23:57
Nice! Makes perfect sense. 8)
PostPosted: March 7th, 2023, 16:11
So it means MHDD limitation or motherboard / system limitation?
