| MHDD with 4TB disk http://forum.hddguru.com/viewtopic.php?f=7&t=41631 |
Page 1 of 1 |
| Author: | wyxchari [ August 28th, 2021, 16:20 ] |
| Post subject: | MHDD with 4TB disk |
Hi. With MHDD I am using a 4TB disk with LBA 7,814,037,168. The problem is that when doing ERASE the final sector 3,519,069,871 appears (slightly less than half). I have tried /DISABLEBIOS when starting MHDD, it goes into PIO mode but the final sector remains the same. Why the limit this one?
| Author: | Samir [ October 31st, 2021, 19:16 ] |
| Post subject: | Re: MHDD with 4TB disk |
Have you tried this on a different motherboard with a different chipset? Could be some sort of limit on the hardware that's affecting the software. |
| Author: | fzabkar [ October 31st, 2021, 23:34 ] |
There appears to be a 32-bit LBA limit.
| Author: | Samir [ October 31st, 2021, 23:57 ] |
fzabkar wrote: There appears to be a 32-bit LBA limit. Nice! Makes perfect sense.
| Author: | Damon [ March 7th, 2023, 16:11 ] |
So it means MHDD limitation or motherboard / system limitation? |
