Tools for hard drive diagnostics, repair, and data recovery
HDD COPY-Now cannot reformat drive
October 17th, 2022, 1:20
I used HDD Raw Copy (V1.10) to create an image from wipemyimage.img. Now if I try to initialize that USB stick with *anything* (Windows 10 Pro), it reports a "volume not mounted" error. I've tried diskpart, Powershell-Initialize-Disk, and even another instance of HDD Raw Copy (using a different image file).
==========Copy an new image to existing HDD Raw Copy USB=====
0/16/2022 9:31:36 PM
10/16/2022 9:31:36 PM HDD Raw Copy Tool 1.10; http://hddguru.com
10/16/2022 9:31:36 PM * * * * * IMPORTANT: DURING THE DUPLICATION PROCESS
10/16/2022 9:31:36 PM ALL DATA ON TARGET WILL BE IRREVERSIBLY OVERWRITTEN!
10/16/2022 9:31:36 PM Source: [0] IMAGE of RAW wipemydisks1.1.img [870.4 MB]
10/16/2022 9:31:36 PM Target: [5] General UDisk 5.00 [2013.26 MB]
10/16/2022 9:31:40 PM Locking device...
10/16/2022 9:31:40 PM Copying...
10/16/2022 9:33:25 PM Write Error occurred at offset 75,431,936 (433)
10/16/2022 9:33:25 PM Cannot write to target, aborting...
10/16/2022 9:33:25 PM Average speed: 5.7 MB/s
10/16/2022 9:33:25 PM Operation terminated at offset 75,431,936 LBA 147,328
=====Windows Diskpart error (Run As Admin)============
C:\WINDOWS\system32>diskpart
Microsoft DiskPart version 10.0.19041.964
Copyright (C) Microsoft Corporation.
On computer: TOM-DEVELOPE
DISKPART> lis disk
Disk ### Status Size Free Dyn Gpt
Disk 0 Online 931 GB 0 B *
Disk 1 Online 1862 GB 1024 KB * *
Disk 2 Online 446 GB 0 B *
Disk 3 Online 465 GB 1024 KB
Disk 4 Online 3726 GB 0 B *
Disk 5 No Media 0 B 0 B
Disk 6 Online 3840 MB 0 B
DISKPART> sel dis 6
Disk 6 is now the selected disk.
DISKPART> clean
DiskPart has encountered an error: The device is not ready.
See the System Event Log for more information.
DISKPART>
How do I remove all information HDD Raw Copy created on the USB stick?
Tom
Windows Computer Manage, Disk Initialize
Re: HDD COPY-Now cannot reformat drive
October 18th, 2022, 10:45
Did you already close HDD copy? It appears it's using FSCTL_LOCK_VOLUME, closing the tool would/should kill the handle and unlock.
Waiddaminute:
I suspect the device is faulty. This was probably just the straw.
