 Post subject: sata to usb-hd adapter
PostPosted: January 4th, 2023, 13:27
Anyone used one of these sata to usb-hd adapters? I'm wondering if I could use it for data recovery with my DDI v4 board? looks interesting!
https://www.dolphindatalab.com/product/ ... apter-pro/
 Post subject: Re: sata to usb-hd adapter
PostPosted: January 4th, 2023, 20:13
Recovery ratio would be higher and the job would complete must faster with proper SATA board.
For the $30 it would cost the lab [you] for a SATA PCB, the client would be much happier w/the result.
With that said, DDI v4 also supports native USB 3.0 - so would this not be redundant?
PostPosted: January 6th, 2023, 12:50
I don't have the DDI4 with usb capabilities. Seems I run into those WD drives as a rule that are direct USB connect on the pcb.. probably others.. yeah the correct sata pcb would be the best route for sure..
