| Informations about DC HC520 12To ? http://forum.hddguru.com/viewtopic.php?f=7&t=43104 |
Page 1 of 1 |
| Author: | qwrty [ February 7th, 2023, 11:32 ] |
| Post subject: | Informations about DC HC520 12To ? |
Hello everyone, I bought some disks from two different ressellers, everythings works fine, but I have some question regarding those disks: Code: Manuf. Model Serial Interface Capacity Type Firmware ---------------------------------------------------------------------------------------------------- 1) HGST HUH721212ALE601 [REMOVE] SATA 12000 GB HDD LEGNX3Q0 HGST Firmware: LEOHX3Q0 2) HGST HUH721212ALE601 [REMOVE] SATA 12000 GB HDD LEGNX3Q0 HGST Firmware: LEOHX3Q0 3) HGST HUH721212ALE601 [REMOVE] SATA 12000 GB HDD LEGNX3Q0 HGST Firmware: LEOHX3Q0 4) HGST HUH721212ALE601 [REMOVE] SATA 12000 GB HDD LEGNX3Q0 HGST Firmware: LEOHX3Q0 5) HGST HUH721212ALE601 [REMOVE] SATA 12000 GB HDD LEGNX3Q0 HGST Firmware: LEOHX3Q0 6) HGST HUH721212ALE604 [REMOVE] SATA 12000 GB HDD LEGNW9G0 HGST Firmware: LEGNW9G0 7) HGST HUH721212ALE604 [REMOVE] SATA 12000 GB HDD LEGNW9G0 HGST Firmware: LEGNW9G0 8) HGST HUH721212ALE604 [REMOVE] SATA 12000 GB HDD LEGNW9G0 HGST Firmware: LEGNW9G0 I'm wondering: - Why firmware is different between "Firmware" column and the HGST Firmware statement for the HUH721212ALE601 model ? (GN mean Generic and OH mean OEM ?) Does this mean previous user flashed them with a generic firmware ? - HUH721212ALE604 firmware seems to be up to date, but I see a firmware update for HUH721212ALE601 => LEGNX9U0 Can I update those disks with this firmware ? - HUH721212ALE601 are SED on the paper: data-sheet-ultrastar-dc-hc520 But, hdparm seems report that the disk is not actually encrypting data (same result for all five disks): Code: hdparm -I /dev/sda Security: Master password revision code = 65534 supported not enabled not locked not frozen not expired: security count supported: enhanced erase What do you think ? - Helium Level is different between 601 et 604: All 601 report Quote: 22 Helium_Level 0x0023 100 100 025 Pre-fail Always - 100 604 report: Quote: 22 Helium_Level 0x0023 100 100 025 Pre-fail Always - 6553700 Hope some hdd guru like napalm_atx or E123 could help me to figure out with all my questions Thank you ! |
| Author: | fzabkar [ February 7th, 2023, 16:01 ] |
| Post subject: | Re: Informations about DC HC520 12To ? |
6553700 = 0x00640064 -> 0x0064 / 0x0064 -> 100 / 100 The raw value looks more logical in hexadecimal. We can see that it consists of two 16-bit words, each reflecting a helium level of 100%. Can you dump the drive's 512-byte Identify Device data block with a tool such as CrystalDiskInfo? |
| Author: | qwrty [ February 8th, 2023, 3:17 ] |
Hum, I see, make sense, that's maybe related to the old firmware ? I can't use CDI, those disks are in a headless Linux server :/ Quote: 601# hexdump -n512 /dev/sdb
0000000 0000 0000 0000 0000 0000 0000 0000 0000 * 00001b0 0000 0000 0000 0000 0000 0000 0000 ff00 00001c0 ffff ffee ffff 0001 0000 ffff ffff 0000 00001d0 0000 0000 0000 0000 0000 0000 0000 0000 * 00001f0 0000 0000 0000 0000 0000 0000 0000 aa55 0000200 604# hexdump -n512 /dev/sdg 0000000 0000 0000 0000 0000 0000 0000 0000 0000 * 00001b0 0000 0000 0000 0000 0000 0000 0000 ff00 00001c0 ffff ffee ffff 0001 0000 ffff ffff 0000 00001d0 0000 0000 0000 0000 0000 0000 0000 0000 * 00001f0 0000 0000 0000 0000 0000 0000 0000 aa55 0000200 |
| Author: | fzabkar [ February 8th, 2023, 12:22 ] |
Try ... Code: hdparm --Istdout /dev/ice
| Author: | qwrty [ February 8th, 2023, 15:46 ] |
601 model Code: /dev/sda: 045a 3fff c837 0010 0000 0000 003f 0000 **************MASKED SN************* 2020 2020 2020 2020 0003 0000 0038 4c45 474e 5833 5130 4847 5354 2048 5548 3732 3132 3132 414c 4536 3031 2020 2020 2020 2020 2020 2020 2020 2020 2020 2020 8010 4001 2f00 4000 0200 0200 0007 3fff 0010 003f fc10 00fb 7910 ffff 0fff 0000 0007 0003 0078 0078 0078 0078 0c18 0000 0000 0000 0000 0000 001f 970e 0076 0cde 0044 03fc 0029 746b 7d69 4773 7469 bc49 4773 407f 824a 8001 00fe fffe 0000 0000 0008 00ca 00f9 2710 0000 0000 7500 0005 0000 00ca 0000 6003 5a87 5000 cca2 70c4 9394 0000 0000 0000 0000 0000 0000 0000 40dc 405c 0000 0000 0000 0000 0000 0000 0000 0021 000b 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0008 4f48 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0002 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 003d 0000 0000 4000 0000 0000 0000 0000 0000 0000 0000 1c20 0000 0000 0000 0000 10ff 0021 0000 0000 0000 0000 0000 0000 0000 7500 0005 0000 0008 0000 0000 0000 0000 0000 0000 0000 0000 4000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 1ca5 604 model Code: /dev/sdg:
045a 3fff c837 0010 0000 0000 003f 0000 **************MASKED SN************* 2020 2020 2020 2020 0003 0000 0038 4c45 474e 5739 4730 4847 5354 2048 5548 3732 3132 3132 414c 4536 3034 2020 2020 2020 2020 2020 2020 2020 2020 2020 2020 8010 4000 2f00 4000 0200 0200 0007 3fff 0010 003f fc10 00fb 5910 ffff 0fff 0000 0007 0003 0078 0078 0078 0078 0d08 0000 0000 0000 0000 0000 001f 970e 0076 0cde 0044 03fc 0029 746b 7d69 4773 7469 bc49 4773 407f 820e 0000 00fe fffe 0000 0000 0008 00ca 00f9 2710 0000 0000 7500 0005 0000 00ca 0000 6003 5a87 5000 cca2 b0e4 7d98 0000 0000 0000 0000 0000 0000 0000 40dc 405c 0000 0000 0000 0000 0000 0000 0000 0001 000b 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0008 474e 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0002 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 003d 0000 0000 4000 0000 0000 0000 0000 0000 0000 0000 1c20 0000 0000 0000 0000 10ff 0021 0000 0000 0000 0000 0000 0000 0000 7500 0005 0000 0008 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 07a5 |
| Author: | fzabkar [ February 8th, 2023, 17:17 ] |
This is the standards document I'm using. I couldn't find a direct download. Sorry. Information technology - ATA Command Set - 4 (ACS-4) - Revision 18, August 4, 2017 https://www.scribd.com/document/4724678 ... et-4-1-pdf Identify Device words 59, 89, 90 appear to be the pertinent ones. AFAICT, the time required for and Enhanced SECURITY ERASE UNIT command in the 601 model is 1 minute. Bit 13 of word #59 is set to 1, so this means that the CRYPTO SCRAMBLE EXT command is supported. The 604 model supports neither command. Therefore it seems that 601 is indeed a SED, and 604 is not. Code: Word 89 O B F Time required for a Normal Erase mode SECURITY ERASE UNIT command (see 7.13.6.43) Code: Word 90 O B F Time required for an Enhanced Erase mode SECURITY ERASE UNIT command (see 7.13.6.44) Code: Word 59 M See 7.13.6.21 B F 15 The BLOCK ERASE EXT command is supported (see 7.34.2) B F 14 The OVERWRITE EXT command is supported (see 7.34.4) B F 13 The CRYPTO SCRAMBLE EXT command is supported (see 7.34.3) B F 12 The Sanitize feature set is supported (see 4.18) B F 11 1 = The commands allowed during a sanitize operation are as specified by this standard (see 4.18.6) 0 = The commands allowed during a sanitize operation are as specified by ACS-2 B F 10 The SANITIZE ANTIFREEZE LOCK EXT command is supported (see 7.34.5) 9 Reserved X 8:0 Obsolete 601 model Code: Offset(h) 00 01 02 03 04 05 06 07 08 09 00000000 045A 3FFF C837 0010 0000 0000 003F 0000 2020 2020 .Z?ÿÈ7.......?.. 00000010 2020 2020 2020 2020 2020 2020 2020 2020 2020 2020 00000020 0003 0000 0038 4C45 474E 5833 5130 4847 5354 2048 .....8LEGNX3Q0HGST H 00000030 5548 3732 3132 3132 414C 4536 3031 2020 2020 2020 UH721212ALE601 00000040 2020 2020 2020 2020 2020 2020 2020 8010 4001 2F00 €.@./. 00000050 4000 0200 0200 0007 3FFF 0010 003F FC10 00FB 7910 @.......?ÿ...?ü..ûy. 00000060 FFFF 0FFF 0000 0007 0003 0078 0078 0078 0078 0C18 ÿÿ.ÿ.......x.x.x.x.. 00000070 0000 0000 0000 0000 0000 001F 970E 0076 0CDE 0044 ............—..v.Þ.D 00000080 03FC 0029 746B 7D69 4773 7469 BC49 4773 407F 824A .ü.)tk}iGsti¼IGs@.‚J 00000090 8001 00FE FFFE 0000 0000 0008 00CA 00F9 2710 0000 €..þÿþ.......Ê.ù'... 00000100 0000 7500 0005 0000 00CA 0000 6003 5A87 5000 CCA2 ..u......Ê..`.Z‡P.Ì¢ 00000110 70C4 9394 0000 0000 0000 0000 0000 0000 0000 40DC pÄ“”..............@Ü 00000120 405C 0000 0000 0000 0000 0000 0000 0000 0021 000B @\...............!.. 00000130 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 .................... 00000140 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 .................... 00000150 0000 0008 4F48 0000 0000 0000 0000 0000 0000 0000 ....OH.............. 00000160 0000 0000 0000 0000 0000 0000 0000 0000 0002 0000 .................... 00000170 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 .................... 00000180 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 .................... 00000190 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 .................... 00000200 0000 0000 0000 0000 0000 0000 003D 0000 0000 4000 .............=....@. 00000210 0000 0000 0000 0000 0000 0000 0000 1C20 0000 0000 ............... .... 00000220 0000 0000 10FF 0021 0000 0000 0000 0000 0000 0000 .....ÿ.!............ 00000230 0000 7500 0005 0000 0008 0000 0000 0000 0000 0000 ..u................. 00000240 0000 0000 0000 4000 0000 0000 0000 0000 0000 0000 ......@............. 00000250 0000 0000 0000 0000 0000 1CA5 ...........¥ 604 Code: Offset(h) 00 01 02 03 04 05 06 07 08 09
00000000 045A 3FFF C837 0010 0000 0000 003F 0000 2020 2020 .Z?ÿÈ7.......?.. 00000010 2020 2020 2020 2020 2020 2020 2020 2020 2020 2020 00000020 0003 0000 0038 4C45 474E 5739 4730 4847 5354 2048 .....8LEGNW9G0HGST H 00000030 5548 3732 3132 3132 414C 4536 3034 2020 2020 2020 UH721212ALE604 00000040 2020 2020 2020 2020 2020 2020 2020 8010 4000 2F00 €.@./. 00000050 4000 0200 0200 0007 3FFF 0010 003F FC10 00FB 5910 @.......?ÿ...?ü..ûY. 00000060 FFFF 0FFF 0000 0007 0003 0078 0078 0078 0078 0D08 ÿÿ.ÿ.......x.x.x.x.. 00000070 0000 0000 0000 0000 0000 001F 970E 0076 0CDE 0044 ............—..v.Þ.D 00000080 03FC 0029 746B 7D69 4773 7469 BC49 4773 407F 820E .ü.)tk}iGsti¼IGs@.‚. 00000090 0000 00FE FFFE 0000 0000 0008 00CA 00F9 2710 0000 ...þÿþ.......Ê.ù'... 00000100 0000 7500 0005 0000 00CA 0000 6003 5A87 5000 CCA2 ..u......Ê..`.Z‡P.Ì¢ 00000110 B0E4 7D98 0000 0000 0000 0000 0000 0000 0000 40DC °ä}˜..............@Ü 00000120 405C 0000 0000 0000 0000 0000 0000 0000 0001 000B @\.................. 00000130 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 .................... 00000140 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 .................... 00000150 0000 0008 474E 0000 0000 0000 0000 0000 0000 0000 ....GN.............. 00000160 0000 0000 0000 0000 0000 0000 0000 0000 0002 0000 .................... 00000170 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 .................... 00000180 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 .................... 00000190 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 .................... 00000200 0000 0000 0000 0000 0000 0000 003D 0000 0000 4000 .............=....@. 00000210 0000 0000 0000 0000 0000 0000 0000 1C20 0000 0000 ............... .... 00000220 0000 0000 10FF 0021 0000 0000 0000 0000 0000 0000 .....ÿ.!............ 00000230 0000 7500 0005 0000 0008 0000 0000 0000 0000 0000 ..u................. 00000240 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 .................... 00000250 0000 0000 0000 0000 0000 07A5 ...........¥ |
| Author: | qwrty [ February 9th, 2023, 5:52 ] |
Quote: Therefore it seems that 601 is indeed a SED, and 604 is not. Yes, but hdparm report that option is not enable: Quote: hdparm -I /dev/sda Security: Master password revision code = 65534 supported not enabled not locked not frozen not expired: security count supported: enhanced erase I mean, I know 601 is SED (I know it from P/N), but i'm wondering how it could be not enable ? |
| Author: | qwrty [ February 9th, 2023, 10:27 ] |
WD Support told me to flash VXGXB9U0.bin my 601s o_O What GX firmware standfor ? |
| Author: | fzabkar [ February 9th, 2023, 13:20 ] |
The security feature set refers to the ATA password. It's not related to SED -- they are two different things. "Not enabled" means that no password has been set. |
