 Post subject: WDR Demo on 64-bit Windows 7 Ultimate
PostPosted: May 15th, 2023, 16:21
Greetings,
I saw on HDD Oracle an article about WDR Demo. I noticed that it requires a 32-bit Windows OS, which Windows XP would work for sure, in addition to having admin access.
However, this is the PC I'm using for HDD repair:
File comment: PC for repairing HDD
I don't have any other PCs that has a spare SATA port or slot(s) for a SATA adapter, and runs on a 32-bit Windows OS. When I checked out the program's properties, I noticed a section on Compatibility mode. Would compatibility mode still allow the program to run and if so, which compatible OS should I run the program in?
Windows XP (Service Pack 3)?
File comment: Properties set for XP SP3
Windows XP (Service Pack 2)?
File comment: Properties set for XP SP2
Or which mode should I run the program in instead? Also, any else not mentioned in the article linked at the top of the post and this article?
 Post subject: Re: WDR Demo on 64-bit Windows 7 Ultimate
PostPosted: May 31st, 2023, 16:10
WDR doesn't work on Win x64 bit systems. You need install x86 system.
PostPosted: May 31st, 2023, 16:26
So even with compatibility mode such as Windows XP SP3, WDR won’t work, am I understanding correctly? I can’t trick WDR into working on Windows 7 Ultimate x64? I’m asking mainly about compatibility mode with WDR.
PostPosted: June 5th, 2023, 16:51
Yes, forget about that compatibility mode, especially on x64 for programs that want x32. I can't remember if that mode once for me.
Another approach would be a bootable x32-windows on a stick or external disk. I have done that in the past (and prefilled with my diagtools), but I don't know if the methods today are better.
BartPE project is dead:
https://en.wikipedia.org/wiki/BartPE
https://nu2.nu/pebuilder/
Don't know if that's any good or supprts x32:
https://www.easyuefi.com/wintousb/
Dirty hacks:
https://itstillworks.com/how-to-install ... 10036.html
Useful tools:
https://rufus.ie (has windows-to-go-mode), also it should run .wim oder .vhd
https://www.ventoy.net/en/index.html can run .vim .vhd
Users browsing this forum: No registered users and 17 guests
