| Hdd raw copy tool is possible open .imgc ? http://forum.hddguru.com/viewtopic.php?f=7&t=43344 |
Page 1 of 1 |
| Author: | faustf [ May 16th, 2023, 4:33 ] |
| Post subject: | Hdd raw copy tool is possible open .imgc ? |
hi i have a meccanical hdd is demage i recover data in .imgc but the hdd not have S.O. because is secondary hdd contain only data , when i try to re-flash over a new hdd arrive till the end but if i attach under my pc not saw partion , is possible open a file .imgc and look inside of recover the data? thanks |
| Author: | Setlec [ May 16th, 2023, 15:35 ] |
| Post subject: | Re: Hdd raw copy tool is possible open .imgc ? |
Any data recovery software should open the *.imgc file if the file is a RAW copy of the drive. What software did you use to make this *.imgc file? R-studio, UFS explorer and DMDE will open any raw copy whatever the extention is (such as img, bin and so on). |
| Author: | ddrecovery [ May 16th, 2023, 15:51 ] |
Setlec wrote: Any data recovery software should open the *.imgc file if the file is a RAW copy of the drive. What software did you use to make this *.imgc file? R-studio, UFS explorer and DMDE will open any raw copy whatever the extention is (such as img, bin and so on). Isn't .imgc a compressed image? |
| Author: | Setlec [ May 16th, 2023, 16:31 ] |
ddrecovery wrote: Isn't .imgc a compressed image? if he used hdd raw copy tool http://hddguru.com/software/HDD-Raw-Copy-Tool/ then it's a raw. But it will depend on confirmation of faustf. |
| Author: | fzabkar [ May 16th, 2023, 16:36 ] |
Quote: Examples of possible uses
Software QA engineers: restore your OS hard drives at any moment from a compressed image |
| Author: | faustf [ May 17th, 2023, 2:44 ] |
yes i used Hdd Raw copy Tool thanks at all for answer |
