| WDR Demo unable to detect patient HDD http://forum.hddguru.com/viewtopic.php?f=7&t=43446 |
Page 1 of 1 |
| Author: | transitNFCtech [ June 28th, 2023, 6:13 ] |
| Post subject: | WDR Demo unable to detect patient HDD |
Greetings, Following this tutorial, I am struggling with getting WDR to detect the patient HDD. This is the PC I am using for WDR: Attachment: Here is what I see in WDR: Main: Attachment:
File comment: Main screen with illuminated indicators WDR Demo main.PNG [ 9.32 KiB | Viewed 15726 times ] Attachment:
File comment: Main screen with Options menu shown Screenshot (2).png [ 304.35 KiB | Viewed 15726 times ] Custom Port: Attachment:
File comment: Custom Port window with selected port WDR Demo Custom Port selection.PNG [ 8.14 KiB | Viewed 15726 times ] WDMarvel Demo has no problem detecting and reading the patient HDD. Is there a way how to get the patient HDD detected and read correctly in WDR? |
| Author: | transitNFCtech [ June 30th, 2023, 3:50 ] | ||||
| Post subject: | Re: WDR Demo unable to detect patient HDD | ||||
I forgot to mention these are the SATA drivers used:
| Author: | mr44er [ July 24th, 2023, 1:38 ] |
What is the disk model? |
| Author: | fzabkar [ July 24th, 2023, 1:50 ] |
Spildit's tutorial expects that the target drive is able to respond to ATA commands. To this end, the easiest solution (in the absence of pro tools) would be to purchase a working donor drive and flash the donor's ROM with the patient's ROM image. You will sacrifice the donor HDD, but your patient drive should now work with the donor's PCB. Of course you should backup the donor's resources. The demo version of WDMarvel can do this. |
