 Post subject: HDD Raw Copy To clone SD card to PC and Back to larger SD ca
PostPosted: November 11th, 2023, 1:13
So I just used HDD Raw Copy To clone SD card to PC and Back to larger SD card. Went from 64 GB on Samsung S20 FE to a 256.
After copying back to the new card, reinsert into phone, phone says it is still 59 GB in size? How to fix?
Reformat SD card and start over?
I used the HDD Raw Copy to keep all original create dates and such, If I just use the USB Cable and shuffle them back and forth after reformat, will my pictures and files keep original dates?
Thanks so much!
Larry
 Post subject: Re: HDD Raw Copy To clone SD card to PC and Back to larger S
PostPosted: November 11th, 2023, 11:21
It's the size of the file system, HDD Raw Copy doesn't resize that. You can try use a partition resizer Amoei or whatever it's called for example.
PostPosted: November 13th, 2023, 13:24
Thanks so much!
Larry
Why didn't you just copy files from one card to the other?
R-Studio Data Recovery Software
PostPosted: November 13th, 2023, 13:30
I was told this was a better way to do it since the copying the files back and forth with change the dates they were created?
So that's what I'm going to do now I already have made it back up I'm just going to go get another 256 GB card and just copy them.
Because I don't have any proof that there's 256 GB card will be utilized past the 59 GB that the phone thinks it is.
PostPosted: November 13th, 2023, 16:20
If you zip all the files, then extract them to new card, it should preserve timestamps.
Otherwise, try using the commandline tool robocopy as described here:
https://superuser.com/questions/146125/how-to-preserve-file-attributes-when-one-copies-files-in-windows
or maybe xcopy will do it as well.
Users browsing this forum: No registered users and 37 guests
