HDD GURU FORUMS
http://forum.hddguru.com/
I need help regarding the MHDD ISO file
http://forum.hddguru.com/viewtopic.php?f=7&t=44423
Page 1 of 1
Author:  crackedpiano [ June 21st, 2024, 8:05 ]
Post subject:  I need help regarding the MHDD ISO file
I've got a bitch drive (160GB HDD) that's driving me nuts I might punch the wall, I need help urgently. After hours HOURS of trying to investigate whats going on with the drive because my computer recognised it (Windows 11) but no applications dedicated to HDD recovery do.
I don't care about the data anymore, I just want the drive to be working again and realised that most applications freeze when the HDD is plugged in.
I eventually found out that is has bad sectors that need remapping and found MHDD, all going smooth; will use, until I download it, try to stick it to the USB for booting and the ISO file is corrupted? I used Rufus btw.
Tried redownloading, tried a different computer tried a different USB stick, different port, different everything, NADA.
Different USB burner, like using UNetbootin caused the computer to shut down when I tried booting from the USB stick later because the ISO doesn't work.
I need a link for either a clean download of the MHDD ISO or another completely free software for remapping bad sectors specifically.
I'm so lost right now
Thanks in advance,
Cracked
Author:  Lukas [ June 22nd, 2024, 6:13 ]
Post subject:  Re: I need help regarding the MHDD ISO file
Post a SMART of this disk so that we can determine the validity of your actions.
http://www.phpbb.com/
