HD Tune x Seatools different results in test HDD
http://forum.hddguru.com/viewtopic.php?f=7&t=44643
Author:  sonicmario [ September 6th, 2024, 15:05 ]
Post subject:  HD Tune x Seatools different results in test HDD
Is it a myth or truth that the best software to test the surface area and bad blocks on a Seagate HDD is Seatools?
I use a Seagate 2.5" 500GB HDD + a Sata to USB 3.0 adapter plugged into the USB 3.0 port on the back of the motherboard. The HD Tune test found a few red blocks, but the Seatools Detailed Generic Test showed the HDD passed the test.
The different results are very strange. Which one is more reliable?
Author:  pepe [ September 6th, 2024, 16:51 ]
Post subject:  Re: HD Tune x Seatools different results in test HDD
do you get the reds at same loc if you test multiple times?
i suspect it is a result of OS interaction with the DUT.
unmount any partitions on that drive and run the test that way
Author:  sonicmario [ September 6th, 2024, 17:00 ]
I performed two or three tests with HD Tune and the same red block in the same place
Is SeaTools reliable and safe for accurate scans?
Author:  Arch Stanton [ September 7th, 2024, 6:02 ]
Yes.
Author:  sonicmario [ September 7th, 2024, 11:56 ]
Is SeaTools reliable and safe for accurate scans or fake?
Author:  Arch Stanton [ September 9th, 2024, 6:03 ]
Yes.
