Page 1 of 1
Need raw firmware (.bin/.fw) for Samsung SM841 (840 Pro OEM)
Posted: August 17th, 2026, 15:10
by anbr6119
Hi everyone,
I am trying to recover a bricked Samsung SM841 OEM SSD from an HP EliteBook laptop. The drive experienced a microcode/panic lock failure and became completely unresponsive (not detected in BIOS).
I have successfully opened the casing and managed to force the Samsung MDX controller into Safe Mode / ROM Mode (SATA_BOOT) by shorting the correct test points (Pins 6 & 7 based on continuity testing to GND). The drive is now recognized in Windows Device Manager as a generic "SATA_BOOT" device under SCSI\Disk IDs.
Since HP has scrubbed their older SoftPaqs from their official support pages, I am unable to acquire the correct OEM firmware package.
Could anyone please share a raw firmware dump or binary file (.bin / .fw) for this specific HP OEM drive?
Here are the exact drive specs from the casing sticker:
    Model: MZ-7PD2560/0H7 (MZ7PD256HAFV-000H7)
    HP P/N: 717354-001
    Original Firmware: DXM05H6Q (or compatible HP OEM release like DXM06B0Q / DXM06H6Q)
Any help or upload link would be highly appreciated.
Thank you in advance!
Re: Need raw firmware (.bin/.fw) for Samsung SM841 (840 Pro
Posted: August 17th, 2026, 15:40
by fzabkar
Are you trying to recover the drive or your data? A firmware upload won't result in a data recovery.
Posted: August 17th, 2026, 17:46
by anbr6119
Just need that firmware as described in post to get that SSD up and running again so that I then can get my data.
Posted: August 17th, 2026, 17:50
by fzabkar
The drive probably has a corrupt Flash Translation Layer. A firmware update won't fix that.
Posted: August 17th, 2026, 17:57
by anbr6119
Might be, have no idea. I have successfully opened the casing and managed to force the Samsung MDX controller into Safe Mode / ROM Mode (SATA_BOOT) by shorting the correct test points (Pins 6 & 7 based on continuity testing to GND). The drive is now recognized in Windows Device Manager as a generic "SATA_BOOT" device under SCSI\Disk IDs. That is a start, now I need to upload new firmware. That is my plan at least.
I have got this link https://www.station-drivers.com/index.p ... 46&lang=en
that seams to be correct driver, but can“t get it to download. I have sent an email to forum admin about it just a minute ago.
Posted: August 17th, 2026, 18:02
by anbr6119
Well, i dont know about that. Have no idea. But right now I really need that driver.
Posted: August 17th, 2026, 18:05
by anbr6119
I have got this link from winraid moderator (same post on that forum) that seems to be correct driver: https://www.station-drivers.com/index.p ... 46&lang=en
But I just cant get it to download...
Is that common on that sajt (not been there before)?
Posted: August 17th, 2026, 21:26
by fzabkar
Mine is not to reason why, but I found this. However, I don't know if it is suitable. I wouldn't apply it in any case.
MZ-7PD256 to SSD 840 PRO (256 GB):
https://www.samsung.com/ca/support/model/MZ-7PD256BW/
Firmware File ver DXM05B0Q 1 MB Jun 04. 2013 Windows MULTI LANGUAGE:
https://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=UNI_CA&OriginYN=N&ModelType=N&ModelName=MZ-7PD256&CttFileID=5457858&CDCttType=FM&VPath=FM%2F201306%2F20130604170817781%2FDXM05B0Q.zip
Posted: August 26th, 2026, 7:40
by anbr6119
I have got the correct firmware now from station-drivers.com:
https://ftp.hp.com/pub/softpaq/sp74501- ... 74967.html
https://ftp.hp.com/pub/softpaq/sp74501- ... p74967.exe
Program does not find my drive since I have put it on SafeBoot. All I get is "[ERROR] There's no available target disk with firmware "DXM06H6Q"".
Are there any documented recovery-process for SM841N / MDX SATA_BOOT other than turn to professional PC-3000 companies?
Posted: August 27th, 2026, 12:52
by fzabkar
anbr6119 wrote:Are there any documented recovery-process for SM841N / MDX SATA_BOOT other than turn to professional PC-3000 companies?
I am not aware of any.
As of Nov 17, 2025, there was no support for Samsung SSDs from Dolphin Data Lab, who are a developer of pro tools. That would suggest that they are not aware of any documented recovery process, either.
DFL SSD Firmware Repair Controllers and Families Support:
https://dolphindatalab.com/dfl-ssd-firmware-repair-controller-and-families-support/
