| N40P g-list problem with PC3K fix http://forum.hddguru.com/viewtopic.php?f=7&t=5566 |
Page 1 of 1 |
| Author: | gbulger [ March 2nd, 2006, 8:31 ] |
| Post subject: | N40P g-list problem with PC3K fix |
I have 2 N40P drives that show G-list as "-" "-" "-" ie 2 dashes rather than 3 check marks. I presume it is corrupt. When I try to correct by going to module correction menu and pressing "ATPOL g-list" to fix it. I get a "module correction error" and the g-list is not fixed. I have the right ldr file and I have tried in master and safe mode. Any suggestions? |
| Author: | bradeanudaniel [ April 10th, 2006, 17:50 ] |
| Post subject: | |
can you help me understand please, master mode and safe mode? thanks. |
| Author: | harddrivefix [ October 25th, 2006, 15:18 ] |
| Post subject: | Re: N40P g-list problem with PC3K fix |
gbulger wrote: I have 2 N40P drives that show G-list as "-" "-" "-" ie 2 dashes rather than 3 check marks. I presume it is corrupt. When I try to correct by going to module correction menu and pressing "ATPOL g-list" to fix it. I get a "module correction error" and the g-list is not fixed. I have the right ldr file and I have tried in master and safe mode. Any suggestions?
your g-list is too corrupt to repair you need to over write the module with another g-list from a similar model the erase the g-list |
| Author: | rameez [ October 26th, 2006, 10:12 ] |
| Post subject: | |
First get the complete firmware of the hdd u want to fix , put the firmware in the pc3k directory then goto the wirte modules option chk module 1B which is glist . rewirte it and the hdd becomes ok Hope that helps!! |
| Author: | valy1965 [ November 2nd, 2006, 15:12 ] |
| Post subject: | Re |
"Check Structure firmware" because I think you have many modules defective in "system area". Regards |
