 Post subject: Hard Disk Low Level Format Tool 2.36 build 1181 Internal err
PostPosted: June 26th, 2006, 23:27
I'm getting an error. The software said I should post it here. It's giving me a lot of format errors, too. It may be that the hard drive is bad.
Current date and time: 6/26/2006 11:09:33 PM
Hard Disk Low Level Format Tool 2.36 build 1181; http://hddguru.com
Device details for Maxtor 6Y160P0 YAR41BW0 [163.92 Gbytes]
Details are unavailable: Internal error.
Please post this problem on http://forum.hddguru.com
PostPosted: June 27th, 2006, 2:38
Site Admin
It seems the only way to figure out if the program has a bug or it is a bad drive is to try it with another drive :oops:
Actually... can you try to extract smart values? This will probably shed some light...
PostPosted: July 10th, 2006, 21:15
I have a problem that may be related on Windows 2000.
On startup, I get two error dialogs:
(X) Error accessing device: Unzulässige Funktion [OK]
(X) Cannot change Visible in OnShow or OnHide. [OK]
Nothing is shown in Device details. There is no menu.
If I then click on S.M.A.R.T. and Get SMART Attributes, I get:
Current date and time: 11.07.2006 03:11:21
SMART Attributes for ·g2xÓg2x·g2xïg2xi2xïg2xñi2xGj2xñi2xcj2x ñj2xcj2x [7475070416,35 Gbytes]
SMART is unavailable because the device is not a Native IDE or SATA device.
However, HDDScan 2.6 works and can access the device(s) without any problems.
Could the problem be caused by the secondary IDE controller which does not do anything useful in this Compaq notebook?
MfG MOW
PostPosted: July 11th, 2006, 19:18
Site Admin
A lot of people report problems on Windows 2000. I do not have Win2k installed, probably will do that one day. I think that there are some problems... have to figure out :oops:
 Post subject: Re: Hard Disk Low Level Format Tool 2.36 build 1181 Internal err
PostPosted: May 14th, 2010, 22:50
I have a same problem, and this a messages from Hard Disk Low Level Format Tool 2.36 build 1181 on tab Device Details
Current date and time: 15/05/2010 9:35:42
Device details for ST3250318AS    CC35    [250,05 Gbytes]
And this a S.M.A.R.T Attributes
Current date and time: 15/05/2010 9:35:48
SMART Attributes for ST3250318AS    CC35    [250,05 Gbytes]
          Attribute                      Current   Worst    Raw       Note
Att: 1    Read error rate                   87       84   153563451
Att: 3    Spin up time                      99       98           0
Att: 4    Number of spin-up times           99       99        1998
Att: 5    Reallocated sectors count         51       51        2029
Att: 7    Seek error rate                  100      253       53863
Att: 9    Power-on time                    100      100         130
Att: 10   Spin-up retries                  100      100           0
Att: 12   Start/stop count                  99       99        1991
Att: 183  Unknown                          100      100           0
Att: 184  Unknown                          100      100           0
Att: 187  Unknown                            1        1        3620
Att: 188  Unknown                           99       99      327687
Att: 189  Unknown                          100      100           0
Att: 190  Unknown                           66       58   572653602
Att: 194  HDA Temperature                   34       42          34  (34 degrees)
Att: 195  Hardware ECC recovered            48       39   153563451
Att: 197  Current pending sectors           96       54         197
Att: 198  Offline scan UNC sectors          96       54         197
Att: 199  Ultra ATA CRC Errors             200      200           0
Att: 240  Unknown                          100      253          39
Att: 241  Unknown                          100      253  1983800444
Att: 242  Unknown                          100      253   758809161
Please help me! :(
PostPosted: May 15th, 2010, 3:18
Your drive has 2029 reallocated sectors and another 197 waiting to be reallocated.
You can use SeaTools to zero fill your drive, but it won't help. Replace it.
http://www.seagate.com/support/seatools/
This article explains the SMART attributes:
http://en.wikipedia.org/wiki/S.M.A.R.T. ... attributes
BTW, attribute 187 is Reported Uncorrectable Errors.
Users browsing this forum: No registered users and 32 guests
