| Hard Disk Low Level Format Tool 2.36 build 1181 Internal err http://forum.hddguru.com/viewtopic.php?f=7&t=5971 |
Page 1 of 1 |
| Author: | pinkie [ June 26th, 2006, 23:27 ] |
| Post subject: | Hard Disk Low Level Format Tool 2.36 build 1181 Internal err |
I'm getting an error. The software said I should post it here. It's giving me a lot of format errors, too. It may be that the hard drive is bad. Quote: Current date and time: 6/26/2006 11:09:33 PM
Hard Disk Low Level Format Tool 2.36 build 1181; http://hddguru.com Device details for Maxtor 6Y160P0 YAR41BW0 [163.92 Gbytes] Details are unavailable: Internal error. Please post this problem on http://forum.hddguru.com |
| Author: | admin [ June 27th, 2006, 2:38 ] |
| Post subject: | |
Hello, It seems the only way to figure out if the program has a bug or it is a bad drive is to try it with another drive Actually... can you try to extract smart values? This will probably shed some light... |
| Author: | MOW [ July 10th, 2006, 21:15 ] |
| Post subject: | |
admin wrote: Hello,
It seems the only way to figure out if the program has a bug or it is a bad drive is to try it with another drive I have a problem that may be related on Windows 2000. On startup, I get two error dialogs: (X) Error accessing device: Unzulässige Funktion [OK] (X) Cannot change Visible in OnShow or OnHide. [OK] Nothing is shown in Device details. There is no menu. If I then click on S.M.A.R.T. and Get SMART Attributes, I get: Current date and time: 11.07.2006 03:11:21 Hard Disk Low Level Format Tool 2.36 build 1181; http://hddguru.com SMART Attributes for ·g2xÓg2x·g2xïg2xi2xïg2xñi2xGj2xñi2xcj2x ñj2xcj2x [7475070416,35 Gbytes] SMART is unavailable because the device is not a Native IDE or SATA device. However, HDDScan 2.6 works and can access the device(s) without any problems. Could the problem be caused by the secondary IDE controller which does not do anything useful in this Compaq notebook? MfG MOW |
| Author: | admin [ July 11th, 2006, 19:18 ] |
| Post subject: | |
A lot of people report problems on Windows 2000. I do not have Win2k installed, probably will do that one day. I think that there are some problems... have to figure out |
| Author: | Dodolz [ May 14th, 2010, 22:50 ] |
| Post subject: | Re: Hard Disk Low Level Format Tool 2.36 build 1181 Internal err |
I have a same problem, and this a messages from Hard Disk Low Level Format Tool 2.36 build 1181 on tab Device Details Code: Current date and time: 15/05/2010 9:35:42 Hard Disk Low Level Format Tool 2.36 build 1181; http://hddguru.com Device details for ST3250318AS CC35 [250,05 Gbytes] Details are unavailable: Internal error. Please post this problem on http://forum.hddguru.com And this a S.M.A.R.T Attributes Code: Current date and time: 15/05/2010 9:35:48 Hard Disk Low Level Format Tool 2.36 build 1181; http://hddguru.com SMART Attributes for ST3250318AS CC35 [250,05 Gbytes] Attribute Current Worst Raw Note ---------------------------------------------------------------------------------- Att: 1 Read error rate 87 84 153563451 Att: 3 Spin up time 99 98 0 Att: 4 Number of spin-up times 99 99 1998 Att: 5 Reallocated sectors count 51 51 2029 Att: 7 Seek error rate 100 253 53863 Att: 9 Power-on time 100 100 130 Att: 10 Spin-up retries 100 100 0 Att: 12 Start/stop count 99 99 1991 Att: 183 Unknown 100 100 0 Att: 184 Unknown 100 100 0 Att: 187 Unknown 1 1 3620 Att: 188 Unknown 99 99 327687 Att: 189 Unknown 100 100 0 Att: 190 Unknown 66 58 572653602 Att: 194 HDA Temperature 34 42 34 (34 degrees) Att: 195 Hardware ECC recovered 48 39 153563451 Att: 197 Current pending sectors 96 54 197 Att: 198 Offline scan UNC sectors 96 54 197 Att: 199 Ultra ATA CRC Errors 200 200 0 Att: 240 Unknown 100 253 39 Att: 241 Unknown 100 253 1983800444 Att: 242 Unknown 100 253 758809161 Please help me! |
| Author: | fzabkar [ May 15th, 2010, 3:18 ] |
Dodolz wrote: Code: SMART Attributes for ST3250318AS CC35 [250,05 Gbytes] Attribute Current Worst Raw Note ---------------------------------------------------------------------------------- Att: 5 Reallocated sectors count 51 51 2029 Att: 9 Power-on time 100 100 130 Att: 187 Unknown 1 1 3620 Att: 197 Current pending sectors 96 54 197 Att: 198 Offline scan UNC sectors 96 54 197 Your drive has 2029 reallocated sectors and another 197 waiting to be reallocated. You can use SeaTools to zero fill your drive, but it won't help. Replace it. http://www.seagate.com/support/seatools/ This article explains the SMART attributes: http://en.wikipedia.org/wiki/S.M.A.R.T. ... attributes BTW, attribute 187 is Reported Uncorrectable Errors. |
