| HDD LLF problem -"Cannot change Visible in OnShow or On http://forum.hddguru.com/viewtopic.php?f=7&t=6009 |
Page 1 of 2 |
| Author: | Xspy [ July 5th, 2006, 12:37 ] |
| Post subject: | HDD LLF problem -"Cannot change Visible in OnShow or On |
Hi, I have problem with run of this program on Windows 2000 . Installation is correct (....i downloaded some old versions too ) , but after run this program write - "Error Acessing Device: Bad function" and "Cannot change Visible in OnShow or OnHide" - After this i look only on clear page in program window . What be missing in my system ? ... I have new installed Windows 2000 SP4 on two computers with same symptoms , under XP this program work correctly. Any suggestion ??? , Thanks |
| Author: | Dmitry Postrigan [ July 5th, 2006, 16:16 ] |
| Post subject: | |
Maybe this program using some functions which are absent in Win2K? |
| Author: | MOW [ July 10th, 2006, 21:57 ] |
| Post subject: | |
maysoft wrote: Maybe this program using some functions which are absent in Win2K?
OK, now I found this thread, sorry ... I just used FileMon while starting HDD LLF, and it shows that LLFTOOL.EXE is trying to open LLFTOOL.DEU, LLFTOOL.DEU.DLL, LLFTOOL.DE, LLFTOOL.DE.DLL in its directory, and then searching its own and the system directories for a uxtheme.dll, all of which are not found. Is that uxtheme.dll the problem? I don't know why LLFTOOL would want to use that at all ... MOW |
| Author: | DjDiabolik [ August 1st, 2006, 13:39 ] |
| Post subject: | Re: HDD LLF problem -"Cannot change Visible in OnShow o |
Xspy wrote: Hi, I have problem with run of this program on Windows 2000 .
Installation is correct (....i downloaded some old versions too ) , but after run this program write - "Error Acessing Device: Bad function" and "Cannot change Visible in OnShow or OnHide" - After this i look only on clear page in program window . What be missing in my system ? ... I have new installed Windows 2000 SP4 on two computers with same symptoms , under XP this program work correctly. Any suggestion ??? , Thanks Hello boys.. i'm new in this forum... i have same error on my PC... After the error i can see a black page of program's and i can't select nothing..... My Os it's Windows XP SP2... CPU Athlon XP 2400+ on Motherboard Asus A7v8x... Ram 512MB DDR 400Mhz. I have 2 HD Matrox..... In Primary Master a Maxtor 6Y080L0 (This HD contains the Os.. Programs ecc. ecc.) and in Primary Slave a 6Y120L0..... i need to low format this HD... Any Suggestion for me ??! |
| Author: | admin [ August 2nd, 2006, 0:49 ] |
| Post subject: | |
Hi What version you are using? |
| Author: | DjDiabolik [ August 3rd, 2006, 6:53 ] |
| Post subject: | |
admin wrote: Hi
What version you are using? ops sorry... 2.36 build 1181. |
| Author: | admin [ August 3rd, 2006, 11:41 ] |
| Post subject: | |
Ok... Since this bug seems to appear not only on win2k PCs I will try to debug it. By the way what was the error message? |
| Author: | DjDiabolik [ August 3rd, 2006, 12:52 ] |
| Post subject: | |
take any moment's...... i make some screenshot... Edit: I just start the program... the first error:
After Press "OK"... second error:
And Finally... The Empty Windows of the programs:
If you are need more information about my PC... please Ask Me. |
| Author: | admin [ August 3rd, 2006, 14:06 ] |
| Post subject: | |
Thanks for screenshots! I will work on this on weekend. |
| Author: | admin [ August 3rd, 2006, 14:07 ] |
| Post subject: | |
By the way, do you have any USB or firewire devices connected? Maybe some flash readers, storage devices etc? What about SCSI boards? That might help |
| Author: | DjDiabolik [ August 4th, 2006, 22:56 ] |
| Post subject: | |
admin wrote: By the way, do you have any USB or firewire devices connected? Maybe some flash readers, storage devices etc?
What about SCSI boards? That might help no... my firewire it's unused... actually i have some cable connect on usb port but then the respective devices are not connected... i have only a convertor for joy PS2 to PC and my Microsoft mouse.... |
| Author: | admin [ August 6th, 2006, 22:58 ] |
| Post subject: | |
Ok, thanks for the info... Still cannot find the problem. Looking further... |
| Author: | DjDiabolik [ August 7th, 2006, 7:11 ] |
| Post subject: | |
ok.. thanks... |
| Author: | claude [ September 4th, 2006, 5:58 ] |
| Post subject: | Same thing |
Hi I'm new in this forum, I have the same problem with Hard disk wipe tool 2.35 build 1178, on a laptop computer without usb disk or compact flash pcmcia conected. regards, claude |
| Author: | omarnas [ June 20th, 2007, 17:32 ] |
| Post subject: | visible in onshow |
The same happened on my machine and I was using it on a USB external drive, it started doing this problem when I had a USB hub connect and the external dive connected to it. I am not sure why, but I hope this infomation could help Regs. |
| Author: | prisonic08 [ November 12th, 2008, 9:38 ] |
| Post subject: | Re: HDD LLF problem -"Cannot change Visible in OnShow or On |
Hi guys, Has there been any developments on getting this issue fixed? I've run into the same problem using both HDDWipe and HDD LLF, on a Windows 2000 SP4 system, no USB devices attached, one system IDE HDD, one SCSI HDD attached via PCI card. Same error messages when opening either program: - 'Error accessing device: Incorrect function' - 'Cannot change Visible in OnShow or OnHide' |
| Author: | ProloSozz [ December 25th, 2008, 18:04 ] |
Same Problem here. The Program ran once as it should - but after quitting and restarting or even deinstalling and reinstalling: no way, always that Problem! |
| Author: | ProloSozz [ December 25th, 2008, 18:21 ] |
Disk Wipe Tool has same problem! |
| Author: | DjDiabolik [ August 27th, 2009, 19:03 ] |
Hey boys... on the same computer i have posted some reply ago....but now with the same XP Professional upgraded with Service Pack 3 this programs working without problems! |
| Author: | BahnStormer [ December 8th, 2010, 8:14 ] |
SOLUTION! I can confirm that Disk Wipe and LLF were both generating this error message on my Dell E4300 (XP SP3) and IBM x60 (win7x86) - the E4300 has definitely been able to run LLF in the past. EJECT THE SD CARDS Job done |
| Page 1 of 2 | All times are UTC - 5 hours [ DST ] |
