| English translation of MxHelp readme. http://forum.hddguru.com/viewtopic.php?f=7&t=6180 |
Page 1 of 1 |
| Author: | bizzybody [ September 4th, 2006, 7:02 ] |
| Post subject: | English translation of MxHelp readme. |
I used http://babelfish.altavista.com to do this. It needs some work now to make it a bit more comprehensible to English type people. Description MxHelp for Windows ver. 2.0. 1. Search for the module of passport and its mapping. 2. Search For the module Of specification. 3. The search for loaded PZU, is derived: - Check sum. - The version of microprogram. New - Status of loaded PZU. New 4. Conclusion from LDR: - the check sum of the loaded BY PZU in LDR. - check sum of the very LDR. of the version of microprogram. New - status of loaded PZU. New - to what family belongs LDR. 5. possibility of renaming LDR: - in the check sum of loaded PZU. - the version of microprogram. New (E7CF_VAM51JJZ.LDR) 6. There is the possibility to tune the survey of passport on your desire into MxHelp.ini and to add the necessary parameters of conclusion or to remove the unnecessary to you. Possibility to add new models nezanesennye into this list and their parameters. New in ini are added the parameters for the work with LDR. Contents of the ravine. Only passport. Name :Value Family :Calypso Name Model :6Y080M042541AC Model 1 :6Y080M2 Code FW :YAR51EW0 Serial :Y21GL3AE Ata :SATA/150 HDD Size :80GB LBA :160086528 Date (Time) :27.4.2004 (4:46) Alphabetic value :KMGA PCBA Pn. IDE Label :T8FYA PCBA Config :54B Unique :1AA HDA Module :42A PGT Cod :203 None :K118 +5V :670 +12V :960 Ver. Module :Q8.39 Check sum ROM :A355 Log $MxHelp.txt remains into the directory with the modules. Editing MxHelp.ini: [Mod] the list of the search for the passport 2F=Ares 64 2B=Athena 2R=Nike 4D=Romulus 4G=Neptune 4R=Falcon 6Y=Calypso 6E=N40P 5T=Rigel Example of tuning the passport: [Mod] 2F=Ares 64 (so it appears in $MxHelp.txt Family:Ares 64) 2F we search for the name of passport in the modules, if they found (=) that it was concluded the name Ares 64 and we pass to the parameters of passport. [2F] Passport. Name=S213,10 Model=S130,14 Model 1=S200,7 Code FW=S152,8 Serial=S0,8 Ata=S238,24 Size=S263,5 LBA=#180,4 Date (Time)=D19,5 Alphabetic value=S88,4 PCBA Pn. IDE Label=S344,5 PCBA Config=S70,3 Unique=S84,3 HDA Module=S64,3 None1=S184,14 Cod=#174,2 None=S57,4 +5V=S288,3 +12V=S292,3 Ver. Module=S505,5 Let us examine some values. Name=S213,10 (so it appears in the ravine $MxHelp.txt Name:DiamondMax Plus 9) Name-the name of position. S- it indicates that we read text value. 213,10- the parameters of reading. From xxx of the address xx of values. LBA=#180,4 (so it appears in the ravine $MxHelp.txt LBA:160086528) LBA-the name of position. #- indicates that we read Hex we transfer into Dec. 180,4- the parameters of reading. From xxx of the address x of values. Date (Time)=D19,5 (so it appears in the ravine $MxHelp.txt Date (Time):27.4.2004 (4:46)) Date (Time)-the name of position. D- it indicates that we read the parameter of date. 19,5- the parameters of reading. From xx the address of 5 values. If it did not be located in [ Mod ] the passport, then program passes to the passport [ 00 ] Default Example of the tuning LDR: In order to make a search for microprogram YAR51EW0 from Calypso necessary to write down in ini thus. [LDR] YR=6Y_Calypso Ardent YR - parameters of search. 6Y_Calypso Ardent - the designation of the parameters of family. Successes in the repairs. Laletin Vyacheslav. All observations and proposals to send. vyacheslav@infocentre.khakasnet.ru http://hddutil.icentre.ru |
