victoria 4 for windows
http://forum.hddguru.com/viewtopic.php?f=7&t=6457
Author:  danrevella [ November 22nd, 2006, 19:13 ]
Post subject:  victoria 4 for windows
hi!
vcr32.ini:
[ATA Port]
PM=1 >>>>>>>>>>>>>
Channel=1
CustomBase=64512
CustomAlt=56320
Remember Primary=1
I have added pm=1 but victoria always tell me that primary port is locked!!
Any help?
Author:  Ruterian [ November 23rd, 2006, 12:26 ]
Post subject:
Enable PM=1
Author:  danrevella [ November 23rd, 2006, 15:06 ]
Post subject:
ditto!!
Enable PM=1
BTW it does NOT works?????
Author:  Ruterian [ November 23rd, 2006, 19:32 ]
Post subject:
danrevella wrote:
ditto!!
Enable PM=1
Checkbox 'only non-destructive functions' must be unchecked.
Author:  danrevella [ November 24th, 2006, 5:00 ]
Post subject:  victoria 4.0
ditto!!
Many thanks, BTW it does NOT works!!!
Author:  rameez [ November 25th, 2006, 13:57 ]
Post subject:
Which system u r using .
Author:  danrevella [ November 25th, 2006, 15:33 ]
Post subject:
windows xp pro sp2 on 4 different computer ........
Author:  valy1965 [ December 1st, 2006, 10:28 ]
Post subject:  re
Here it's *.ini
BinToFile=0
Only EC=0
+reset=0
AllDev=0
AltStat=1
TermoCtrl=1
HPA Tmp=0
HPA Mb=0
[Hint]
Hints=0
[SMART Checkboxes]
SaveBIN=1
[ATA Port]
Enable PM=1
Channel=1
CustomBase=54272
CustomAlt=55298
Remember Primary=1
[Seek]
Method=0
Timeout=100
[Security]
Method=1
Level=0
Password=password
Author:  danrevella [ December 1st, 2006, 10:50 ]
Post subject:
Thanks for the ini, but the problem is that I always get "Error Privileged instruction" in every function I try to use.....
Author:  valy1965 [ December 1st, 2006, 11:21 ]
Post subject:  re
I have a capture screen but I can't uploaded in this Forum , maybe in PM.
Download this version(with porttalk included) and try.
http://www.mytempdir.com/1092261
Author:  valy1965 [ December 1st, 2006, 11:28 ]
Post subject:  re
here it's a capture screen with primary master enable:
http://www.mytempdir.com/1093513
Author:  Doomer [ December 1st, 2006, 13:32 ]
Post subject:
I talked with author and he said - this is a local time format problem
He uses TimeToStr function with another time format (like in Russia)
He fixed it but still does not release new version
BTW you can ask author (Ruterian) a question through PM
Author:  danrevella [ December 1st, 2006, 15:04 ]
Post subject:
This is avery good news!!!
Many thanks!!!
Author:  darkfroce1 [ December 3rd, 2006, 5:01 ]
Post subject:  PIO To File
In dos we could take PIO to image. But how to take in windows. Can any one explain it
DS
Author:  danrevella [ December 3rd, 2006, 9:39 ]
Post subject:
Victoria 4.1 now works wery well, btw to obtain the maximum from this program I hope a BartPE plugin really need.
I try by myself, but with no result.
The advantage of running Victoria under BartPE environment:
-) you may gain full access to all HD: windows is loaded from cdrom
-) there will NOT be other background process that always runs in windows even if we even don't know they.....
-) results will NOT be falsed by I/O slowdown time relatiding to windows program/service running in background.
-) will be possible to repair a primary hd who fails even in loading windows...
Author:  ivanlexpc [ January 19th, 2007, 0:34 ]
Post subject:  Tnaks
Nice, i don't knew about victoria, thanks
