| These seek error + access times OK for Seagate ST3160812A ? http://forum.hddguru.com/viewtopic.php?f=7&t=6703 |
Page 1 of 1 |
| Author: | Shplad [ February 11th, 2007, 17:55 ] |
| Post subject: | These seek error + access times OK for Seagate ST3160812A ? |
Hi there: First, let me thank you for making what looks like a superb tool for testing drives. I haven't seen anything else that comes close. It looks like a very powerful tool. Now I just need to learn to understand what the test results mean. I just replaced a friend's dying drive with a brand new Seagate 160GB ST3160812A IDE drive. The motherboard is an Asus TUSI-M with latest BIOS, SiS 630 chipset. Spinrite 6 results indicated about 256,000 seek errors, but no other errors. I tested the drive will all the Seagate long diags., and it passed them all. When I ran MHDD scan on the drive I got these results: Code: 11.02.2007 15:47:00
11.02.2007 15:47:00 11.02.2007 15:47:00 | MHDD 4.6 (c) Dmitry Postrigan | FREEWARE 11.02.2007 15:47:00 Changing mode to: IDE 11.02.2007 15:47:18 Changing mode to: IDE 11.02.2007 15:47:18 Device selected: 1 11.02.2007 15:47:19 11.02.2007 15:47:19 MHDD>HELP 11.02.2007 15:47:37 11.02.2007 15:47:37 MHDD>SMART ATT 11.02.2007 15:47:37 Getting SMART attributes... 11.02.2007 15:47:37 SMART READ ATTRIBUTES 11.02.2007 15:47:37 HDD: ST3160812A; FW: 3.AAJ; SN: 9LS0E3M9 11.02.2007 15:47:37 -------------------------------------------------------- 11.02.2007 15:47:37 SMART attributes: 11.02.2007 15:47:37 Name Val Worst Raw 11.02.2007 15:47:37 Att # 1 : Read error rate : 97 94 49166809 11.02.2007 15:47:37 Att # 3 : Spin up time : 97 97 0 11.02.2007 15:47:37 Att # 4 : Number of spin-up times : 100 100 3 11.02.2007 15:47:37 Att # 5 : Reallocated sectors count : 100 100 0 11.02.2007 15:47:37 Att # 7 : Seek error rate : 65 60 3274505 11.02.2007 15:47:37 Att # 9 : Power-on time : 100 100 39 11.02.2007 15:47:37 Att # 10 : Spin-up retries : 100 100 0 11.02.2007 15:47:37 Att # 12 : Start/stop count : 100 100 5 11.02.2007 15:47:37 Att # 187 : Unknown : 100 100 0 11.02.2007 15:47:37 Att # 189 : Unknown : 100 100 0 11.02.2007 15:47:37 Att # 190 : Unknown : 64 60 672923684 11.02.2007 15:47:37 Att # 194 : HDA Temperature : 36 40 36 11.02.2007 15:47:37 Att # 195 : Hardware ECC recovered : 49 47 15163629 11.02.2007 15:47:37 Att # 197 : Current pending sectors : 100 100 0 11.02.2007 15:47:37 Att # 198 : Offline scan UNC sectors : 100 100 0 11.02.2007 15:47:37 Att # 199 : Ultra ATA CRC Error Rate : 200 200 0 11.02.2007 15:47:37 Att # 200 : Write error rate : 100 253 0 11.02.2007 15:47:37 Att # 202 : Unknown : 100 253 0 11.02.2007 15:47:44 11.02.2007 15:47:44 MHDD>7 11.02.2007 15:47:51 11.02.2007 15:47:51 MHDD>SCAN 11.02.2007 15:47:51 ST3160812A LBA: 312,581,808 11.02.2007 15:47:51 SN: 9LS0E3M9 FW: 3.AAJ 11.02.2007 15:48:09 Scan started 11.02.2007 15:48:09 MODE: IDE 11.02.2007 15:48:09 Device: ST3160812A 11.02.2007 15:48:09 F/W: 3.AAJ 11.02.2007 15:48:09 SN: 9LS0E3M9 11.02.2007 15:48:09 ------------------------------- 11.02.2007 15:48:09 Lap : 1 11.02.2007 15:48:09 LBA scan: 0 to 312581807 11.02.2007 16:34:26 Time spent: 00:46:15 11.02.2007 16:34:26 Blocks < 3ms = 1027486 11.02.2007 16:34:26 Blocks < 10ms = 198094 11.02.2007 16:34:26 Blocks < 50ms = 232 11.02.2007 16:34:26 Blocks < 150ms = 0 11.02.2007 16:34:26 Blocks < 500ms = 0 11.02.2007 16:34:26 Blocks > 500ms = 0 11.02.2007 16:34:26 No warnings, no errors 11.02.2007 16:34:26 Done 11.02.2007 16:42:11 11.02.2007 16:42:11 MHDD>SCREENSHOT 11.02.2007 16:42:11 11.02.2007 16:42:28 11.02.2007 16:42:31 MHDD>HELP 11.02.2007 16:42:53 11.02.2007 16:42:53 MHDD>PORT 11.02.2007 16:42:59 Changing mode to: IDE 11.02.2007 16:42:59 Device selected: 1 11.02.2007 16:44:23 MHDD>SCREENSHOT 11.02.2007 16:44:29 11.02.2007 16:44:31 MHDD>EXIT 11.02.2007 16:44:31 MHDD: Exit At the beginning of the disk, it seemed like almost all blocks were <3ms, then towards the middle, it went higher to <10 and occasionally <50, then closer to the end of the disk, it went back to mostly <3 ms. Does this seem okay for a brand new drive? I don't know that much about drives, Do the slow times correspond with the many seek errors in SpinRite? Could it be AAM that is causing the seek errors? I looked at some S.M.A.R.T. tools, but I just get confused by the attribute statistics. Thanks in advance for any help. Shplad |
| Author: | Dmitry Postrigan [ February 12th, 2007, 8:18 ] |
| Post subject: | |
Hi and welcome! From this log I can tell that the drive is in perfect healthy condition! Forget about spinrite =) |
| Author: | Shplad [ February 12th, 2007, 11:17 ] |
| Post subject: | |
Maysoft: Thank you very much! That is a big help for me. So that I can learn for myself how to interpret the numbers, could you point me to a webpage or some resource that explains what "value" "worst" and "raw" mean? Also, are there some guidelines for knowing what the seek times should be for new, medium-age and older drives? Even though I'm a technician, I find drive test and S.M.A.R.T. results very confusing to understand. Finally, I have a suggestion-I hope you don't mind. Over on Spinrite's newsgroup, users are creating a sort of database of drives, with their drive test results, and comparing them to figure out criteria for when a drive might be starting to fail or failing. Would you possibly consider doing that here? It would be fairly easy to do, I think. Thanks again. You made a big contribution to this area. Shplad maysoft wrote: Hi and welcome!
| Author: | Dmitry Postrigan [ February 14th, 2007, 12:02 ] |
| Post subject: | |
Regarding the detailed info about SMART, I suggest you to use the following DOC: http://hddguru.com/content/en/documenta ... I-8-rev2b/ Most of these values are vendor sprcific. There is no doc on those values. Why do I know what those values mean? I used to work with hard drives... Just experience |
