| SCSI Hard Drive CAPACITY http://forum.hddguru.com/viewtopic.php?f=7&t=6770 |
Page 1 of 2 |
| Author: | martcom [ March 1st, 2007, 7:26 ] |
| Post subject: | SCSI Hard Drive CAPACITY |
Hard Drive CAPACITY CHANGE for non seagate drives seagate drives i can do with seatools IDE i can do with mhdd Other make SCSI drives i can not Anyone HELP ??? |
| Author: | Doomer [ March 1st, 2007, 10:58 ] |
| Post subject: | |
Mode sense command does this |
| Author: | martcom [ March 2nd, 2007, 6:26 ] |
| Post subject: | |
Doomer wrote: Mode sense command does this
Were can i get that from please ?? |
| Author: | Doomer [ March 2nd, 2007, 8:44 ] |
| Post subject: | |
t10.org - get SCSI standard from here Mode Sense it is standard SCSI command |
| Author: | martcom [ April 16th, 2007, 5:51 ] |
| Post subject: | Hard Drive CAPACITY CHANGE for non seagate drives |
Hard Drive CAPACITY CHANGE for non seagate drives Still looking for some software to do this with can any one help please please please |
| Author: | hddguru [ April 16th, 2007, 15:19 ] |
| Post subject: | Re: Hard Drive CAPACITY CHANGE for non seagate drives |
Unicap.exe |
| Author: | martcom [ April 17th, 2007, 10:13 ] |
hddguru wrote: Unicap.exe
Thanks and i can down load this from ??????????????/ |
| Author: | Dmitry Postrigan [ April 17th, 2007, 16:00 ] |
| Post subject: | |
Actually, if I remember correctly, MHDD restores full HDD capacity when you ussie a SCSI low level format command (i do not recall what is the command, sorry, but you can try to issue a HELP command to find out |
| Author: | martcom [ April 18th, 2007, 5:14 ] |
| Post subject: | |
maysoft wrote: Actually, if I remember correctly, MHDD restores full HDD capacity when you ussie a SCSI low level format command (i do not recall what is the command, sorry, but you can try to issue a HELP command to find out
i think that is for IDE drives not SCSI I can do it wth SEAGATE SCSI drives just not other makes and i need to |
| Author: | Doomer [ April 18th, 2007, 8:08 ] |
| Post subject: | |
martcom wrote: maysoft wrote: Actually, if I remember correctly, MHDD restores full HDD capacity when you ussie a SCSI low level format command (i do not recall what is the command, sorry, but you can try to issue a HELP command to find out :-)) i think that is for IDE drives not SCSI SCSI format cannot be implemented for IDE drives, so you are wrong |
| Author: | martcom [ April 18th, 2007, 12:26 ] |
| Post subject: | |
Doomer wrote: martcom wrote: maysoft wrote: Actually, if I remember correctly, MHDD restores full HDD capacity when you ussie a SCSI low level format command (i do not recall what is the command, sorry, but you can try to issue a HELP command to find out i think that is for IDE drives not SCSI SCSI format cannot be implemented for IDE drives, so you are wrong Ok so if i am wroug tell me were i can get what i am looking for to do the job then !!!!!! |
| Author: | Doomer [ April 19th, 2007, 7:46 ] |
| Post subject: | |
Dmitry said - RTFM do it ! |
| Author: | martcom [ April 19th, 2007, 10:06 ] |
| Post subject: | |
Doomer wrote: Dmitry said - RTFM
do it ! Well i have RTFM and can not see any thing in there about changeing HDD capacity on SCSI drive Need this as the drives i have are set to 4Gb and the drive is a 20Gb so this is the only way it can be done. SEAGATE drives have a tool to do this but i can not find it to do other drives so again please help |
| Author: | Doomer [ April 19th, 2007, 12:15 ] |
| Post subject: | |
martcom wrote: Doomer wrote: Dmitry said - RTFM do it ! Well i have RTFM and can not see any thing in there about changeing HDD capacity on SCSI drive What help said about SCSI format ? Anyway, you could change capacity with Mode Select command, try to find program for sending SCSI commands (For example, Bus Hound can send SCSI-command to a SCSI-drive, I beleive there are many other programs) Read SCSI-standard (from t10.org) for Mode Select and Mode Sense command and do this After changing capacity you should start SCSI format (every SCSI controller with BIOS can do this) If you cannot understand these things - pay somebody for this job |
| Author: | martcom [ April 20th, 2007, 8:02 ] |
| Post subject: | |
Doomer wrote: martcom wrote: Doomer wrote: Dmitry said - RTFM do it ! Well i have RTFM and can not see any thing in there about changeing HDD capacity on SCSI drive What help said about SCSI format ? Anyway, you could change capacity with Mode Select command, try to find program for sending SCSI commands (For example, Bus Hound can send SCSI-command to a SCSI-drive, I beleive there are many other programs) Read SCSI-standard (from t10.org) for Mode Select and Mode Sense command and do this After changing capacity you should start SCSI format (every SCSI controller with BIOS can do this) If you cannot understand these things - pay somebody for this job Hmmmmmmm well i would not pay you !!!!!!!!!! |
| Author: | Doomer [ April 20th, 2007, 9:10 ] |
| Post subject: | |
Relax, I do not need your money :) Just DIY and stop bugging people |
| Author: | hddguru [ April 20th, 2007, 15:21 ] |
| Post subject: | |
Doomer wrote: Relax, I do not need your money Just DIY and stop bugging people |
| Author: | rameez [ April 20th, 2007, 16:01 ] |
| Post subject: | |
To martcom , u should show some respect if u need to learn . |
| Author: | martcom [ April 23rd, 2007, 8:12 ] |
| Post subject: | |
Just DIY and stop bugging people Sorry i thowrt this was a forum where you could get help from others if you read the the post all i did was ask for HELP |
| Author: | Doomer [ April 26th, 2007, 17:04 ] |
| Post subject: | |
martcom wrote: all i did was ask for HELP
I do not have program with one button "Change SCSI Capacity" especially for you, but I have written step-by-step manual for you where I "chewed" all staff, "swallow" it, please I cannot "swallow" for you |
| Page 1 of 2 | All times are UTC - 5 hours [ DST ] |
