Remove password and update firmware
http://forum.hddguru.com/viewtopic.php?f=7&t=7138
Author:  HubbenTo [ May 21st, 2007, 3:57 ]
Post subject:  Remove password and update firmware
Hello...
Maby someone can help me with this?
My hdd (ST380011A, Barracuda 7200,7 firmware 8.01) is locked in a Xbox. Now an error in first sector make it unbootable.
I try to unlock it with several password i culd remember, but no good.
I can hook it up with a program to read and write to the hdd bios, and its ok. I wonder how to use the program, ST_MEM_FREE, to update the firmware and remove the password on the hdd?
I don't understand how to use the files that ends with **.trk.
Best regards
HubbenTo
Author:  rameez [ May 25th, 2007, 3:06 ]
Post subject:
This program requires a special hardware that is the COM port cable which u can built on your on and for using this program u need to learn terminal commands .
Author:  HubbenTo [ May 26th, 2007, 4:15 ]
Post subject:
Hi, and thanks for the answer..
Yes, thats right, i build an interface to comunicate via the com port.
I manage to unlock a ST310014ACE, following this tutorial: Unlocking Tutorial Seagate ST310014ACE v0.1 by cyd0g.
Maby one can do the same trick with a ST380011A..???
Someone here on this forum maby can give me a hint?
Author:  HarshReality [ May 29th, 2007, 11:53 ]
Post subject:
Maybe somebody here can construct the cable and sell it to me.. .I have no idea where I would aquire that chip without having to order it
Author:  alex2549 [ June 14th, 2007, 10:51 ]
Post subject:  Re: Remove password and update firmware
Hi.
I don't know if it could help you, but try here....
http://www.seagateunlock.com/
and here.....
http://hddguru.com/content/en/software/2005.10.02-MHDD/
good luck!
HubbenTo wrote:
Hello...
Best regards
HubbenTo
