 Post subject: Damaged clusters?
PostPosted: July 23rd, 2007, 6:30
I have a SATA Seagate hdd running on WXP. Recently i've been experienced some problems accessing to some files. Chkdsk /f /r says that some clusters are damaged (about 4), but hddscan reports that there aren't damaged blocks.
My question is: are 'block' (hddscan) and 'cluster' (chkdsk) the same concept?.
How can i be sure that it is safe and reliable to keep using that hdd?
Thank you very much in advance!.
Sergio.
 Post subject: Re: Damaged clusters?
PostPosted: July 28th, 2007, 23:41
Hi sergiales.
I think a Block size = 1 in hddscan have a size of 512 byte and correspond to a sector.
A cluster with WXP summarizes 8 sectors and has then normally a size of 4096 byte.
Set the Blocksize, in hddscan to 8 and try it then again.
Sorry, my English is extremely bad. :roll:
Users browsing this forum: No registered users and 33 guests
