| Damaged clusters? http://forum.hddguru.com/viewtopic.php?f=7&t=7438 |
Page 1 of 1 |
| Author: | sergiales [ July 23rd, 2007, 6:30 ] |
| Post subject: | Damaged clusters? |
Hi, I have a SATA Seagate hdd running on WXP. Recently i've been experienced some problems accessing to some files. Chkdsk /f /r says that some clusters are damaged (about 4), but hddscan reports that there aren't damaged blocks. My question is: are 'block' (hddscan) and 'cluster' (chkdsk) the same concept?. How can i be sure that it is safe and reliable to keep using that hdd? Thank you very much in advance!. Sergio. |
| Author: | WeesNix [ July 28th, 2007, 23:41 ] |
| Post subject: | Re: Damaged clusters? |
Hi sergiales. I think a Block size = 1 in hddscan have a size of 512 byte and correspond to a sector. A cluster with WXP summarizes 8 sectors and has then normally a size of 4096 byte. Set the Blocksize, in hddscan to 8 and try it then again. Sorry, my English is extremely bad. |
