How to erase slow sectors
http://forum.hddguru.com/viewtopic.php?f=7&t=7494
Author:  cybernick [ July 31st, 2007, 9:44 ]
Post subject:  How to erase slow sectors
I do not care about the data and the capacity I will loose. Just is there a method to erase (make them totally unusable) the slow sectors? If so which software and how?
I tried MHDD but it did not help me (erase, scan erase delay and remap did not help)
Author:  Dmitry Postrigan [ July 31st, 2007, 19:13 ]
Post subject:  Re: How to erase slow sectors
Short answer - there is no way to do that :)
Longer answer - some people probably can do that, but in most cases it does not make sense because the drive will die very soon anyways.
Sorry :oops:
Author:  cybernick [ August 1st, 2007, 6:48 ]
I send one of HDD in that state to a tech guy. He did something and fixed it. He did not tell me? I am sure that there should be a solution. I do not care I can even loose the half capacity.
Author:  rameez [ August 4th, 2007, 13:21 ]
which brand is the hdd ? And the best solution for these drives is selfscan .
Author:  cybernick [ August 5th, 2007, 9:55 ]
The drive is Toshiba MK2023GAS. Any idea about this
Author:  RJARRRPCGP [ August 5th, 2007, 12:48 ]
I suggest that you use Victoria and try again. It seemed to catch slow sectors better.
Author:  aleste81 [ September 29th, 2007, 22:27 ]
http://files.hddguru.com/
search makebad it transform slow sectors into bad.
