 Post subject: USB HDDs
PostPosted: November 5th, 2007, 1:40
Please tell me the solution of my problem:
I want to buy 250 GB seagate Hard Disk Drive. I want to know that does it support on P5PE-VM Motherboard and in an IBM R52 Series Laptop through USB, without any conflict and error. I want to use it as an externel HDD.
mail to sandeepgupta85@gmail.com
 Post subject: Re: USB HDDs
PostPosted: November 5th, 2007, 14:07
Hi Sandeep
There is no issue with the capacity and model of hard disk as you want to use it externally.
you can use it
DF :)
DF :)
www.datatracksystem.net
PostPosted: November 11th, 2007, 2:15
Hi Sandeep,
I Will Like To Add .Make Sure Your USB Hardware Can Support The Capacity You Plan To Use And Its USB 2.0 For Fast Data Transfers .
