Cannot Detect SATA
http://forum.hddguru.com/viewtopic.php?f=7&t=7903
Author:  asiaddrc [ October 18th, 2007, 0:55 ]
Post subject:  Cannot Detect SATA
I am using a MSI VIA P4M890/900 Board which is an Intel Core 2 Pentium system.
It seems that when I attached a SATA HDD to it and run MHDD, MHDD does not detect the drive. Any advice?
But when I switch it to RAID on the Bios setting it was able to detect it but it runs on the PIO mode which is very slow. I need the speed of processing especially when running those big capacity drive.
thanks
Ben
From Singapore
Author:  RJARRRPCGP [ November 12th, 2007, 13:14 ]
Post subject:  Re: Cannot Detect SATA
MHDD running at PIO speeds is a known issue for all chipsets newer than early 2002!
I can tell that it is, because the erase command is slow!
MHDD erases at PIO speeds with my Asus A7N8X-X (nForce2) and MSI 845E Max. (Intel 845E)
But it was at UDMA speeds with an old Intel 810-based Gateway.
