| USB HDDs http://forum.hddguru.com/viewtopic.php?f=7&t=7990 |
Page 1 of 1 |
| Author: | sandeep_chd [ November 5th, 2007, 1:40 ] |
| Post subject: | USB HDDs |
Hello, Please tell me the solution of my problem: I want to buy 250 GB seagate Hard Disk Drive. I want to know that does it support on P5PE-VM Motherboard and in an IBM R52 Series Laptop through USB, without any conflict and error. I want to use it as an externel HDD. mail to sandeepgupta85@gmail.com |
| Author: | darkforce1 [ November 5th, 2007, 14:07 ] |
| Post subject: | Re: USB HDDs |
Hi Sandeep There is no issue with the capacity and model of hard disk as you want to use it externally. you can use it DF |
| Author: | Amarbir[CDR-Labs] [ November 11th, 2007, 2:15 ] |
Hi Sandeep, I Will Like To Add .Make Sure Your USB Hardware Can Support The Capacity You Plan To Use And Its USB 2.0 For Fast Data Transfers . |
