 Post subject: DAT drive / tape drive test software
PostPosted: January 21st, 2008, 16:25
Has anyone got or no were i can get software to test and fix DAT drive / tape drive
Many thanks
Hard drives from 10Mb to 2Tb MFM/RLL/SCSI/IDE/SATA/PATA/SAS
DRIVES / PCB / BOARDS
 Post subject: Re: DAT drive / tape drive test software
PostPosted: January 22nd, 2008, 11:42
Software to fix DAT drive?
Probably need hardware like a hammer :)
Hint: Often problem with DAT drives - dirty heads
PostPosted: January 22nd, 2008, 14:53
When dat drives have faults they are recorded in the service area memory. After a certain number of errors or errors of a certain type drives become useless or unusable for backup as the device needs to be 'factory serviced'. I guess you would need 'in house' software or even hardware to delete the records.
