| master file currupt http://forum.hddguru.com/viewtopic.php?f=7&t=8609 |
Page 1 of 1 |
| Author: | datasolution [ March 3rd, 2008, 8:44 ] |
| Post subject: | master file currupt |
hello friends i ve one new problem in my 80gb seagate sata hard-drive.it does not show first partition(bootable).but shows rest of three correct.i can see data and copy data.but the primary partition did not show.when i use reocvery softwares it shows all data,but i need to be boot from my drive.means i need to recover partition.there are some license inside so i ve to boot from this drive.when i use scandisk it shows "master file table currupt" chkdsk is not posiible.so what to do ?pls help me.thanx in advance.i ve used lost and found partition,ptd etc. |
| Author: | pepe [ March 15th, 2008, 7:20 ] |
| Post subject: | Re: master file currupt |
Hi, U should copy the data off the bad partition using another HDD to boot from. Then format and reinstall the OS and copy data back. pepe |
