Low level format time is to long?
http://forum.hddguru.com/viewtopic.php?f=7&t=9060
Author:  hakkareally [ May 22nd, 2008, 12:37 ]
Post subject:  Low level format time is to long?
Hi
My pc harddisk is unavilaible, i was find this site from google and download last hddguru low level format software.
I started to format, but its tine to long. Between 3-10 hours. Is it normal?
Author:  Deck [ June 3rd, 2008, 1:23 ]
Post subject:  Re: Low level format time is to long?
It’s not normal, i think. To my knowledge, low level format will take within half an hour on an 80 GB harddrive.
Author:  dick [ June 3rd, 2008, 5:11 ]
Hi!
Not sure if a low level format will fix the drive problem!
Anyway two things are missing here......how fast is the pc and how large is the drive capacity. Its obvious twice the size = 2x the time and the same goes for cpu speed.
If the drive has any bad sectors to be reallocated it could easily take as long as you describe.
A test scan in MHDD or Victoria would give you a good idea of the drive's condition. You would need to take note of the read times in milliseconds. I often use Victoria for windows and when I run a test scan I set the timeout to 250ms.
