| Fun questions. :) http://forum.hddguru.com/viewtopic.php?f=9&t=10598 |
Page 1 of 2 |
| Author: | N.C. [ November 29th, 2008, 7:46 ] |
| Post subject: | Fun questions. :) |
Hello gurus, If somebody knows funny question about dr, please write down here... Like "where is the P list? - In the filter!"... Let me start: What says mhdd, when we try to measure the RPM in SSD? Janos |
| Author: | scratchy [ December 1st, 2008, 4:49 ] |
| Post subject: | Re: Fun questions. :) |
Talking about SSD I think the motor has seized in mine as I cant hear it spinning. It seems to work perfectly though .. |
| Author: | N.C. [ December 1st, 2008, 5:41 ] |
scratchy wrote: Talking about SSD I think the motor has seized in mine as I cant hear it spinning. It seems to work perfectly though .. Only sometimes make clicking noise? |
| Author: | rameez [ December 2nd, 2008, 14:06 ] |
Can i swap maxtor pcb to wd , both are 20gb ? |
| Author: | shahij [ December 2nd, 2008, 16:37 ] |
Hey, what r u talking about - I cant understand what is HDD, pls explain me. |
| Author: | hddguy [ December 3rd, 2008, 5:09 ] |
A customer sent us 3 platters in an envelope with nothing else! He said 'he thought he could read them directly from his CD drive'!!! |
| Author: | N.C. [ December 3rd, 2008, 5:10 ] |
lol. |
| Author: | prodata [ December 3rd, 2008, 5:21 ] |
a pretty woman lost her beautifull Picture that she save in her Harddrive, it is knocking and she got no idea.. Open the HDA and see to the platter and say Loudly : " Finnaly I can See My Picture There.. Hmmm I'm So Beautifull and SEXY.... |
| Author: | rameez [ December 4th, 2008, 13:14 ] |
My pcb is burnt can i send u the pcb so u can recover my data ? |
| Author: | N.C. [ December 4th, 2008, 16:55 ] |
Today, i have one case: One 2B020H1 maxtor.... "My son have runs one virus scanner, and now the drive disapeared, not showed in the bios. Can you disinfect my drive to get my data back?" (G-list overflow) Janos |
| Author: | shahij [ December 7th, 2008, 11:40 ] |
N.C. wrote: Today, i have one case: One 2B020H1 maxtor.... "My son have runs one virus scanner, and now the drive disapeared, not showed in the bios. Can you disinfect my drive to get my data back?" (G-list overflow) Janos You can fix it, upgrade the bios. |
| Author: | shahij [ December 7th, 2008, 11:41 ] |
N.C. wrote: (G-list overflow) Janos For that, transfer to H/I/J/K etc... |
| Author: | pepe [ December 22nd, 2008, 15:23 ] |
The PCB on my SSD is burnt by a power surge. I need the data. Can I simply replace it from the same model, or do I have to match the firmware revision? pepe |
| Author: | N.C. [ December 22nd, 2008, 17:01 ] |
pepe wrote: The PCB on my SSD is burnt by a power surge. I need the data. Can I simply replace it from the same model, or do I have to match the firmware revision? pepe If you have a matching FW, you should try hotswap! |
| Author: | prodata [ December 22nd, 2008, 22:59 ] |
N.C. wrote: pepe wrote: The PCB on my SSD is burnt by a power surge. I need the data. Can I simply replace it from the same model, or do I have to match the firmware revision? pepe If you have a matching FW, you should try hotswap! if not help. Put it in refrigerator over night or double boil it. |
| Author: | irs [ December 30th, 2008, 7:07 ] |
no i don't believe refrigerator should work, try head swap! |
| Author: | pepe [ December 30th, 2008, 11:56 ] |
... I swapped my head, but the drive is just as bad as it was... But at least I feel better. pepe |
| Author: | N.C. [ December 30th, 2008, 15:32 ] |
irs wrote: no i don't believe refrigerator should work, try head swap! You not believe, because your refrigerator is too lean! Watch this methode: http://www.youtube.com/watch?v=4CzLI9Z5Wx4&NR=1 |
| Author: | salvationlaura [ December 31st, 2008, 3:35 ] |
One True Story of HD One day, a pretty woman could not find her mirror, so she opened one HD, exactly speaking, a 80Gb HD instead of a 40Gb because she thought the platter of 80Gb was twice larger than the 40Gb's. She removed the platter outside from the enclousure and looked at it, her makeup was still in good order. She felt better and happy. Suddently, she remembered that she forgot signing her name on one Important Business Plan (.doc). So she took her pen and wrote her name on the platter. After she putting the platter back to the enclosure. The drive worked perfectly and she could see her signautre on that Bussiness Plan. It was a true story. |
| Author: | N.C. [ December 31st, 2008, 4:24 ] |
She definitely had a good magnetic ballpen. |
| Page 1 of 2 | All times are UTC - 5 hours [ DST ] |
