For those who ask alot about knoking hdd
Posted: June 5th, 2011, 7:02
Dear newbies
Based on the facts that i got to know and many testing/experiment i got to know that each knocking sound from diff. hdd`s (i.e. WD, seagate...) has its own symptoms
my suggestion for you guys is the following TOOL, i use it alot for quick diagnose
just as a hint, get your self few hundreds of WORKING hdd (wd, seagate....)
power ON and listen (Stick n Save the process in ur memory)
Compare it later with working once in ur Brain
with proper tools you can fix it, later on you may judge the problem and fix it easily
this is how i do?
it might be Funny but Works for me.
thank you
this is how i do?
thank you
