HDD GURU FORUMS
http://forum.hddguru.com/
Different look of WD inernal drives
http://forum.hddguru.com/viewtopic.php?f=9&t=41471
Page 1 of 1
Author:  MNijbracht [ July 5th, 2021, 12:13 ]
Post subject:  Different look of WD inernal drives
I didn't know where to place this topic. so to avoid argument with the mod on maybe a less critical topic I'll just place it here.
I generally find Western digital sells for the same type of drive. For instance WDnnEZRZ slightly different designs. See picture. Could you tell beforehand which type ypu're gonna receive as a customer?
Is A for instance sold in yhe ISA and B in Europe?
I think that type A is made in Malaysia and B in Thailand. Though googling I f?ound that Thailand also makes type A. shell for some models. Resellers are never accurate about what they have in stock. And calling them is a bit of a hassle.
Author:  fzabkar [ July 5th, 2021, 19:21 ]
Post subject:  Re: Different look of WD inernal drives
The suffix is different. This means they belong to different families, Apollo versus Giant. They have 6 and 8 heads, respectively, so the 6-head model would appear to be more recent.
https://support-en.wd.com/app/warrantystatus
WD40EZRZ-22GXCB0
APOLLO
5400
64M
SATA3 6GB/S
4.0 TB
6HD
SECOND TIER OEM
WD40EZRZ-00WN9B0
GIANT
5400
64M
SATA3 6GB/S
4.0 TB
8HD
STD
Author:  MNijbracht [ July 7th, 2021, 15:49 ]
What does STD mean. Like in standard or retail version?
Author:  fzabkar [ July 7th, 2021, 16:03 ]
Probably.
Note that "00GXCB0" would be the retail version, whereas "22GXCB0" would be an OEM version. "GXC" is the family code.
See http://www.acelab.ru/dep.pc/doc.pc3000dos/060713.001/WD-main-N-2.pdf (Russian)
    22 = customer ID (00 = generic)
    GXC = family identifier
    B0 = customer configuration code
http://www.phpbb.com/
