Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
 Post subject: Re: Best way to repair bad sectors?
PostPosted: April 17th, 2010, 6:03
Right or wrong, it kills. Even factory procedures sometimes kill the drive... imagine a software.
PostPosted: April 17th, 2010, 12:53
Well ,
when the BAD Sectors Are Few No Issue Use It And enjoy It will do the What It Says ,Many Others Will Also do that .You Can Use any
PostPosted: June 1st, 2020, 14:06
Drive with bad sectors should be replaced to newone (always!).
RATUJ-DANE odzyskiwanie danych
PostPosted: June 2nd, 2020, 13:11
Over the years, I have become much more concerned with making restorable backups onto external media than with reviving slightly beginning to fail platter-driven hard-drives. Back then, I used Spinrite before and after backup or restore operations ground to a halt. Now, I systematically, routinely, make backups while the hardware and software are working together seamlessly. I average two C-partitions and two D-partition backups about every two weeks. Now, I do use HardDisk Sentinal to periodically run short quick tests on current internal and external platter-driven hard-drives.
+1 to both lcoughey and drc!
"Take care of thy backups and thy restores shall take care of thee." Ben Franklin revisited
Users browsing this forum: DrZ and 109 guests
